Username Post: Heaater/AC control unit        (Topic#351115)
william1180
Reg: 05-14-18
05-14-18 07:56 PM - Post#2733997
All the indicators are constantly flashing. The system seems to work accordingly. I tried anothe heater/AC control unit and got the same result. Where should I be looking to find a problem?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
05-15-18 02:48 AM - Post#2734001
    In response to william1180
Clean the contacts on the unit and plug with contact cleaner spray.
william1180
Reg: 05-14-18
05-15-18 07:12 AM - Post#2734024
    In response to junkman104
Good idea! I tried this and no change.
When ignition is turned on all seems normal. A few moments later and the selected position indicators all start to flash. All functions seem to work. Turning the key off and on again shows a normal condition,few moments later abnormal condition.Strange it did this with a replacement unit too.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
05-15-18 09:34 AM - Post#2734034
If it is the temperature arrows, the actuator is bad.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
william1180
Reg: 05-14-18
05-15-18 09:24 PM - Post#2734078
    In response to bowtie44s
Thanks Jeff, I'll check this . Also the direction of air flow does the same thing. I can change both temperature and direction of air flow. Just the arrows on both flashing.Although I hadn't actually checked the airflow movement to verify where it was coming out.I'll check that next.
scrambldcj8
scrambldcj8
Loc: MA
Reg: 04-06-03
05-16-18 03:03 AM - Post#2734080
Possibly a blend door is not operating/opening FULLY. My 94 K Blazer has been doing the "flash dance" for years when I put it to "Defrost"....it still defrosts the windshield so I just ignore it.
I even have a brand new AC/Heat dash control unit that I do not need....hint hint
william1180
Reg: 05-14-18
05-17-18 08:50 PM - Post#2734224
    In response to scrambldcj8
Thanks for the tip on the blend door activity.I'll be checking that in a couple of days.Some other tips I've received to be checked out also.
Don't need a new unit as I also have a spare now that I ordered last week. It also had the same results. so it's obviously not the control unit.
william1180
Reg: 05-14-18
12-06-18 08:35 PM - Post#2753694
Just an update to my first post: Followed all the tips and had same result. So I pulled the temp controller off and dissected it. Only a couple of plastic gears and a tiny motor. All looked clean. Gave the motor a few twists with my fingers. Reassembled and adjusted the timing position on the drive cog and reinstalled. All issues disappeared instantly. The complete unit is working perfectly again.
Thanks for the tips and suggestions, appreciated.
Execution time: 0.097 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:42 AM
