Username Post: Starting problems new owner        (Topic#350904)
Rnl364
Reg: 04-30-18
04-30-18 05:43 PM - Post#2732707
Just purchased a 67 convertible which is somewhat of a project car. The radiator support needed to be replaced and the previous owner took off the hood, driver side fender, inner and outer and grill assembly and wiring harness to the headlights. I replaced the support, got the fenders, grill and hood replaced. I tried to start the car, key does nothing. Using a remote start, I got the car to crank but not run. Spark is getting to plugs, carb is pumping gas, I was wondering if the light harness needs to be connect in order to start up. Has a crate 350 engine with hei ignition. Have thoughts would be greatly appreciated. Wiring appears to be all original
J C
Loc: Orange Co. Calif
Reg: 04-17-04
05-12-18 10:07 AM - Post#2733778
    In response to Rnl364
Not really sure but I don't think so. You can bench start an engine with minimal wiring.
69RSZ28 71 Chevelle 79 Silverado 24K mi.
Mad Professor
Reg: 12-30-08
10-15-18 11:24 AM - Post#2748741
Make sure the HEI has full voltage and is not wired into any resistors. Make sure rotor is timed to #1 on compression stroke (f order 18436572)
62 Willys wagon
67 CJ5 Buick V6 w/OD
85 C10 305, SM465
89 S10 baja package
Rnl364
Reg: 04-30-18
11-07-18 10:01 PM - Post#2750738
    In response to Mad Professor
Finally got the car running. In order to start the car I turn the key for a few seconds, cranking strong but will not turn over until I release the key. When key is released engine fires up with no problem. Any thoughts on how I could correct this issue. Thanks for your replies
11-08-18 04:01 PM - Post#2750804
Do you have 12v to the distributor when cranking the engine?
DECEASED
11-09-18 04:09 PM - Post#2750917
I agree with Shepherd. It sounds as though whoever installed the HEI may have wired it to the wrong terminal on the ignition switch.
vabeach56wagon
vabeach56wagon
Loc: Chesapeake,VA,
Reg: 04-22-02
11-14-18 01:04 PM - Post#2751391
You are correct. Don't ask me how I know.
Original builder of the Gobstomper - '56 210 9 passenger wagon now in other's hands. Current Ride is '69 X33D80 Z28 Camaro
Execution time: 0.403 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:10 PM
