My heater blower runs at low speed when the ignition switch is in the run position. Moving the speed switch has no effect on the blower. Moving the Mode and Temp select levers have no effect. How is the best way to trouble shoot this problem?
When you strike first, you don't have to get even
Edited by wukong on 04-06-18 01:15 PM. Reason for edit: No reason given.
