41wildthing
Loc: NJ
Reg: 12-02-15
03-17-18 09:58 AM - Post#2727936
Hello everyone. My 1941 Chevy has the original 216 ci engine and the side cover is leaking. I have purchased a new gasket and I'm ready to install it but I have a couple of questions.
At the bottom rear corner of the side cover is it possible to get that bolt out without removing the starter or not. I'd rather not have to do that if I don't need to. I will be disconnecting the ground cable for safety.
Any advise will be much appreciated.
Thanks....Phil
2blu52
Deceased Member RIP
Reg: 03-12-02
03-17-18 10:49 AM - Post#2727943
In response to 41wildthing
If it a stove bolt screw get an off set screw driver. I replaced that particular screw with a bolt.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON |
41wildthing
Loc: NJ
Reg: 12-02-15
03-17-18 11:02 AM - Post#2727946
In response to 2blu52
Thank you 2blu. I am not sure what kind of bolt it is yet, but did yours clear the starter? My starter is a 12 volt standard size unit.
Thanks again....Phil
2blu52
Deceased Member RIP
Reg: 03-12-02
03-17-18 02:50 PM - Post#2727975
Cannot help with the 12V starter, I am a hide bound 6 volt person
THOMAS JEFFERSON |
Jerry L. Weeks
Reg: 03-19-22
03-20-22 10:59 AM - Post#2838426
I changed mine without removing starter and mine is 1941 Chevy Special Deluxe.
