Username Post: Engine mounting brackets        (Topic#350007)
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
03-08-18 03:27 PM - Post#2726911
I recently bought a 1961 Corvette which was an abandoned restoration project. The chassis needed some repair work - both of the little angle brackets welded to the chassis to carry the engine mounting brackets had torn out of the chassis on the underside. One had been very badly welded. When I set out to repair these faults, I found that the left-hand engine mounting bracket (the one welded to the bottom of the chassis) was an inch and a half further back than the right-hand one. (Might have been the other way round - I forget).
Any ideas what this is all about?
DECEASED
03-08-18 10:49 PM - Post#2726956
    In response to Hugomiller
It sounds as if the car might have been converted to side engine mounts. You might be able to patch those up, but first look at a stock mounting setup to see if it would work out better for you.
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
03-09-18 06:28 AM - Post#2726972
Ah - being new to Corvettes, I thought this was the stock set-up! There is a little angle bracket welded to the top of the frame, and a corresponding one underneath. Then there is a bracket bolted to these that carries the engine mounting. What should there be?
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
03-09-18 07:52 AM - Post#2726981
I am trying to attach a photo - I didn't realize you had to pay a subscription to do that. I have happily paid, but I still can't post it - I presume it hasn't gone through yet. I'll have another go later.
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
03-09-18 09:57 AM - Post#2726994
Attachment: DSC01284.JPG (263.06 KB) 37 View(s)
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
03-09-18 09:58 AM - Post#2726995
Finally figured out how to do it! This is the view inverted.
DECEASED
03-09-18 10:09 AM - Post#2726997
After seeing your pic and later description, I am now sure you do have the stock mounting setup. This just wasn't apparent from your initial post. I apologize for giving you a scare.
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
03-09-18 12:04 PM - Post#2727017
Is it common for these to tear out of the frame? And I presume they are each meant to be the same distance from the front of the frame? Mine are way out. I think the hole in the bracket that engages with the rubber mountings had been enlarged to compensate (not sure of the details as I'm currently in the UK and the car is in Florida).
I've been reading online that some people have replaced the rubber mountings with solid aluminium - that sounds a bit radical, doesn't it?
Edited by Hugomiller on 03-09-18 12:05 PM. Reason for edit: No reason given.
DECEASED
03-09-18 12:53 PM - Post#2727024
No, I have never seen a bracket tear out like that, although I suppose it is possible if the frame were rusted badly enough. I would suggest waiting until you have the "saddle" bolted to the engine before you decide where you want to position the frame brackets. Then install the brackets so as to get the best alignment of the holes. Of course you will have to support the engine while you are doing this.
The stock rubber mounts are similar to those used in 52-54 passenger cars and the complete assembly is quite strong because it doesn't have any rubber-to-metal bonds. You can't actually "break" the mount unless you break the through bolt. Replacing the rubber parts with aluminum won't gain you any strength, but can transmit vibration to the frame, which I think you would find unpleasant.
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
03-09-18 01:33 PM - Post#2727032
Thank you so much. When I have cleaned and painted the chassis, I intend to drop the engine & gearbox in before I re-fit the body, & see how it runs (or IF it runs - it's allegedly been rebuilt but hasn't been run for very many years). So that will be a good opportunity to get everything lined up properly.
There is no rust on the chassis - it's an Alabama car & looks like it's been off the road since 1982!
The chassis also had a nasty ding underneath where it looks like somebody tried to jack the car up about one third of the way back, but we heated it up & knocked it out.
Before doing that, I had the chassis up on stands & dropped plumb lines from various points & measured all the diagonals - luckily everything was good to within a millimetre or so.
Attachment: DSC01268.JPG (272.72 KB) 43 View(s)
Here's an example of the previous owner's welding!
Edited by Hugomiller on 03-09-18 01:34 PM. Reason for edit: No reason given.
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
03-09-18 01:42 PM - Post#2727033
Attachment: DSC01245.JPG (171.72 KB) 37 View(s)
And here's my chassis ding :( The phot is flipped upside down for some reason)
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
03-09-18 01:53 PM - Post#2727034
Note the plumb lines & marks on the floor.
Attachment: DSC01250.JPG (174.75 KB) 36 View(s)
DECEASED
03-11-18 12:09 PM - Post#2727215
Those welds do look amazingly bad, even for home-made. This revives my earlier conjecture that the PO converted to side engine mounts and then wanted or needed to go back to stock at a later date.
In case you were wondering, there can actually be a legitimate reason for wanting to ditch the stock mounting setup - coolant leaks. This is because the bolt holes in the saddle and water pump have enough clearance that the engine can rock back and forth under reversing torque loads. This rocking motion compromises the gasket seal and you get a leak.
A perfectly good fix would have been a couple of dowel pins through the saddle and into the block, but for some reason GM chose not to go this route. I have tried this myself and found it to work with no unpleasant side effects other than having to do it again if an engine swap was desired later on. For best effect, the dowel holes should be drilled and reamed with the saddle bolted tightly to the block.
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
03-11-18 01:10 PM - Post#2727217
Thank you again for your insights. These welds are about my standard of welding. Which is why I always get others to do my welding! The chassis also has a new battery tray welded on, to the same standard, which I will have to deal with.
As regards the water leak, I have read on the internet about this. Somebody solved this problem by welding legs onto the saddle pointing downwards, although I'm not clear what they were bolted to.
Your solution sounds neat though.
Execution time: 0.125 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:25 PM
