 Page 4 of 6 « First<3456
Username Post: Tommy49's 1949 Deluxe Sport Coupe        (Topic#349880)
Mel Foye
Mel Foye
Reg: 09-29-00
04-17-19 09:45 PM - Post#2764442
    In response to tommy49
Way to go Tommy. I have taken autobody classes at local colleges but my back kept me mostly reading and watching others.
Got a very little time on shrinker/stretcher but enough to tell this is really a key for curves etc.
For strength and design that roller unit looks killer. Miller tig is frosting on the cake.
Enjoy your new toys--er I mean your new 49 work tools.
Bel Air kiwi
DECEASED
Bel Air kiwi
Reg: 04-24-14
04-18-19 11:56 PM - Post#2764532
Hi Tommy, does your intake manifold still have the alignment sleeves in place. These are important in avoiding intake leaks.
They are also a great help in keeping the gasket in place during assembly.
Did you put the manifolds together and check their trueness?
Workshop looks very sanitary and good clean place to work.
Cheers Kiwi
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
04-19-19 04:42 AM - Post#2764544
    In response to Mel Foye
Hey, Mel!
I hear you about the back. I have osteoarthritis, and Ankylosing Spondylitis, auto-fusion of the spine, shoulders, and neck. All my joints feel and sound like bad wheel bearings, but as long as I'm still vertical and above room temperature, I'm good!
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
tommy49
tommy49
Reg: 09-28-12
04-19-19 05:12 AM - Post#2764547
    In response to Bel Air kiwi
Cheers Kiwi
Hello, Kiwi,
All of those items were checked and triple checked. It looks like I've fixed the
problem. Actually the problem(s) are the 3 junk carbs I've been working with. Carb #1 was soaked in carb cleaner and rebuilt, but it just wouldn't idle. I took the accelerator pump from carb #1 and put it in carb #2, the base from carb #3, and that carb ran good, except for the bog down on fast acceleration. I suspected an internal leak, so I stole the bowl gasket from carb #1, and that seems to have cleared the bog down issue. Carb #3 was a parts carb. Right now, I'm looking for a remanufactured replacement, just in case my "custom" carb fails.
Welcome to my shop and thank you for the compliment. We still haven't finished painting.
Tommy
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
04-19-19 05:43 PM - Post#2764604
Hey Tom, I got tired of digging through piles of carbs., cheated and bought Two Chinese replacement Carbs for 250-292.
reason for edit, carbs were $93.00 each.
52 Styleline Fourdoor 62 235 PG
Edited by gcrkfrd on 04-19-19 05:45 PM. Reason for edit: No reason given.
Franks_Old_53
Franks_Old_53
Loc: Atlanta, GA, USA
Reg: 11-16-02
04-20-19 04:54 AM - Post#2764624
    In response to gcrkfrd
Very nice work on the '49, Tommy! The car is looking great. It's amazing how so many people in the past used bondo as the end-all, be-all solution for all kinds of damage. I mean, come on, they repaired the FRAME with that stuff? Sheesh......
And I like the shop - always good to have the right tools (you can NEVER have too many tools).
David
Accountant by profession, wanna-be car restorer by choice
Rebuilding my Granddad's 1953 Chevy 150 https://www.chevytalk.org/fusionbb/showtopic.php?t...
tommy49
tommy49
Reg: 09-28-12
04-20-19 06:18 AM - Post#2764631
How do they work? What brand? I'm looking at a Sherryberg, just like the Rochester B I have for $200. I also sent All American Carburetor an email on remanufactured carb prices and the cost of having one done prices.
Tommy
tommy49
tommy49
Reg: 09-28-12
04-20-19 06:50 AM - Post#2764632
    In response to Franks_Old_53
David
The left side of the 49 is bondo, window screen, galvanized tin, and pop rivets, just like the right side was. After what I learned repairing the right side, buying the tools is going to make the work easier and with a better outcome.
I agree with never having too many tools, but, my 30' x 42' 3 bay shop is down to a 2 bay shop and I'm out of space. Kat threw my woodworking equipment out of her workshop, so I lost a bay. Now I'm trying to figure if I should expand the shop or build a new shop. I have to do something, Kat thinks it would be cool to have an English wheel.
Tommy
tommy49
tommy49
Reg: 09-28-12
04-26-19 07:16 AM - Post#2765073
I posted in the main forum about the radiator failure trashing the trans, and now, the 49 project is going to go in a different direction. We decided, actually Kat suggested it, that we abandon 235/700r4 and do the LR4/4l60e and MII front suspension kit with power steering, that we've talked about. We have a 2001 GMC pickup that we don't use, so that's the donor. Kat says I need the direction change to keep my enthusiasm up. So, we'll do what it take get the 49 up and running and start gathering the parts for the LS conversion. I think what prompted Kat into the LS conversion is the crappy ride in the 49. She also watches the car shows and feels it's the way we should go. If mama ain't happy, ain't nobody happy!
Tommy
tommy49
tommy49
Reg: 09-28-12
08-18-19 09:27 AM - Post#2773478
We've been so busy around here, I haven't had quality time to spend on the 49's ls swap, but that's project's starting up. We finally finished painting the shop and adding the cataract surgery in both eyes, wow. what a difference! And I thought all the bulbs were going dim.
Attachment: shop_painted_1.JPG (161.87 KB) 22 View(s)
Attachment: shop_painted_2.JPG (161.23 KB) 22 View(s)
Attachment: shop_painted_3.JPG (161.43 KB) 24 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
08-18-19 09:31 AM - Post#2773479
The teardown of my donor pickup has started and new parts are piling up. I have the new fuel system and the IFS waiting to go in the 49. I hope to have the engine & trans out within the next week, so I can get that out of the shop and on craigslist.
Attachment: ls_swap_1.JPG (161.17 KB) 23 View(s)
Attachment: ls_swap_2.JPG (153.39 KB) 24 View(s)
Attachment: ls_swap_3.JPG (148.03 KB) 23 View(s)
Attachment: ls_swap_4.JPG (161.65 KB) 24 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
10-23-19 05:48 AM - Post#2778556
Finally got started working on the 49. Engine & suspension are out, the brake system is sucked dry, and fuel tank drained. Game plan today is finish prepping frame for the MII suspension and pull the fuel & brake systems, and exhaust. A new high pressure fuel system is going in and the brake lines are now going to be routed on the left side of the frame. I'm going to route the right front brake line around the front of the frame. All this to eliminate brake lines over/under the trans. Let the fun begin!
Attachment: LS_swap_begins_1.JPG (160.96 KB) 24 View(s)
Attachment: LS_swap_begins_2.JPG (161.88 KB) 18 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
10-25-19 06:12 AM - Post#2778725
Yesterday, I started fitting the TCI MII and starting with the crossmember, I learned NOT to take the instructions seriously. The crossmember rear studs DON'T match up to the existing frame holes, as indicated by the instructions. Now that I've drilled new holes for those studs, I have to massage the frame holes that are being used for bolts. After all of that, then I get to drill the holes that ARE called out in the instructions. I can see already this will be a fun install!
Attachment: crossmember_studs_1.JPG (156.38 KB) 19 View(s)
Attachment: crossmember_studs_2.JPG (142.69 KB) 18 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
10-25-19 06:17 AM - Post#2778726
For those that may be interested, I will document every issue I come across with this MII install and what I did to correct it.
Tommy
tommy49
tommy49
Reg: 09-28-12
10-27-19 09:55 AM - Post#2778872
The crossmember is now in and I set the shock towers up to check dimensions. The instructions call for 13.25" from the center of the forward bumper hole to the side of the shock tower. I found this dimension canted the shock back a couple degrees. I couldn't find a reason to cant the shock back like that, so, using the protractor, I set the shock at 0 degree's. My dimension came to 13". I'm good with that. Now I can disassemble and weld up unused holes.
Attachment: shock_alignment_1.JPG (160.1 KB) 23 View(s)
Attachment: shock_alignment_2.JPG (160.58 KB) 22 View(s)
Attachment: MII_install_1.JPG (157.62 KB) 16 View(s)
Tommy
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
11-02-19 02:57 AM - Post#2779350
Hey Tommy- you don't need no stinking instructions!
Love your work.
Dean50
tommy49
tommy49
Reg: 09-28-12
11-02-19 03:28 AM - Post#2779351
    In response to Dean50
Hey Dean, thanks! How's everything down in the old stompin' grounds?
Tommy
tommy49
tommy49
Reg: 09-28-12
11-10-19 07:58 AM - Post#2779890
Another issue I had was the distance between the upper control arm mounting brackets, The instructions call out 27 3/8" between outer surfaces and say to grind off material to get that dimension. I was under that dimension, so I added some 14ga to the front edge and 12ga to the back edge of both towers.
Before:
after:
Attachment: shock_tower_measurement_1.JPG (160.34 KB) 15 View(s)
Attachment: shock_tower_measurement_2.JPG (153.97 KB) 18 View(s)
Attachment: shock_tower_measurement_3.JPG (158.87 KB) 22 View(s)
Attachment: shock_tower_measurement_4.JPG (158.55 KB) 18 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
11-10-19 08:05 AM - Post#2779891
So now, I checked the angle the the upper control arm brackets. The spec is 0 deg +/- 5 deg.
Perfect!
Now I'm confident that there shouldn't be any issues with alignment.
Attachment: upper_control_arm_angle.JPG (172.03 KB) 24 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
11-10-19 08:53 AM - Post#2779894
I still have to weld the top of the shock towers, but I wanted to check the fit of the Walton Fabrication engine mounts.
The mounts fit, but I need to make the fit a little cleaner. Too much material hanging over the frame edge.
Attachment: MII_setup_1.JPG (165.98 KB) 21 View(s)
Attachment: walton_engine_mount_1.JPG (151.62 KB) 18 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
11-10-19 08:59 AM - Post#2779895
The plan is still to do a full suspension assembly for fit and then disassemble it to work on the firewall. I'm not going to weld the engine mounts in yet so I don't slice my shins up standing between the frame rails.
Tommy
tommy49
tommy49
Reg: 09-28-12
11-14-19 01:21 PM - Post#2780152
Haven't been in the shop much the last couple days, but I did manage to trim down the engine mount flanges. The fit looks much better.
Attachment: walton_engine_mount_2.JPG (158.17 KB) 23 View(s)
Tommy
drock55
Loc: Caddo Oklahoma
Reg: 01-17-18
11-14-19 01:37 PM - Post#2780153
Mel Foye
Mel Foye
Reg: 09-29-00
11-16-19 10:03 PM - Post#2780328
Perfect!
Will your caster come ALL from shims? Is there camber gain designed into this setup? As usual your work blows me away! Mel
Will yor caster
tommy49
tommy49
Reg: 09-28-12
11-17-19 08:41 AM - Post#2780348
The caster adjustment comes from the slots in the upper control arm brackets, shims for the camber.
Attachment: shock_tower_weld_2.JPG (153.07 KB) 21 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
11-25-19 11:39 AM - Post#2780925
Not much to show, too many distractions. So far, I've removed the firewall braces and trimmed the body supports. Next is heater and insulator removal to weld up unused holes.
Attachment: firewall_mods.JPG (159.62 KB) 14 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
12-12-19 02:40 PM - Post#2782019
When we pulled the 4.8 out of the pickup, I needed an engine stand. I searched around and found these cradles at Jegs for under $29.00 each, free shipping. I modified one so I could mount the trans to the engine.
Attachment: engine_stands_1.JPG (161.93 KB) 11 View(s)
Attachment: engine_stands_2.JPG (161.26 KB) 10 View(s)
Attachment: engine_stands_3.JPG (157.31 KB) 11 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
12-12-19 02:52 PM - Post#2782020
Set the engine in and now I have to remove the trans crossmember and frame braces. I need more room to tuck the exhaust up. I also worked on a section of exhaust pipe to clear the frame. I'll splice this into the new exhaust system. My Miller tig welder was great on the stainless exhaust.
Attachment: engine_fit_1.JPG (152.22 KB) 11 View(s)
Attachment: left_side_exhaust_clearance.JPG (151.92 KB) 11 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
12-18-19 11:28 AM - Post#2782407
Christmas came early! Yesterday my exhaust parts came and, after 3 weeks at the dealers for service, my new tractor was delivered. Now I can blow snow in comfort!
Attachment: exhaust_parts.JPG (160.94 KB) 11 View(s)
Attachment: emax_25.JPG (178.05 KB) 11 View(s)
Tommy
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
12-18-19 08:38 PM - Post#2782451
Very nice Christmas gifts......YOU MUST HAVE BEEN A VERY GOOD BOY!!!!!!!!'
Bill Wilson 50 styleline deluxe 2 door sold,- 51 styleline Deluxe 2 door ,'56 235 with dual carter webers on an Offenhauser intake, Fenton headers, 56 chevy rear end and 700R4 transmission.
Execution time: 0.147 seconds.   Total Queries: 30   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:56 AM
