 Page 11 of 11 « First<891011
Username Post: Tommy49's 1949 Deluxe Sport Coupe        (Topic#349880)
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
05-02-21 04:19 AM - Post#2819136
    In response to tommy49
Just a heads up when you get that far in your build, vehicle speed signal for the C/C module has to come from somewhere, hopefully from your pcm, that will simplify things. my best guess is to follow the vss wires from the trans to see where they go. The other thing to consider is tire diameter. Some difference from the donor truck to your car will have little or no effect on the C/C.
1950 Fleetline, 355 TBI, mild cam, 700R4, 3.73 posi rear Blazer axle, MII front. P/W, Remote door and trunk locks, GM cruise control, A/C.
https://www.flickr.com/photos/54237519@N00/a lbums
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
05-02-21 11:48 AM - Post#2819161
    In response to johnwd98
The vss signal comes from the trans. Programming for tire size & gear ratio is on my list of items for my programmer. I have a whole list of add & delete questions for him.
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, MII IFS, Blazer rear axle, 4 wheel power disc brakes, power steering, air conditioning.
johnwd98
johnwd98
Reg: 09-05-10
05-03-21 04:34 AM - Post#2819192
Ok, good, sounds like you already have done some research on that. Hope it all works out well.
tommy49
tommy49
Reg: 09-28-12
05-03-21 07:52 AM - Post#2819203
Most of my online time is research, probably why I'm not one to post questions. Research helps me weed out the useful and the bs.
Tommy
Edited by tommy49 on 05-03-21 07:53 AM. Reason for edit: No reason given.
Execution time: 0.177 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:51 PM
