 Page 7 of 7 « First<4567
Username Post: Tommy49's 1949 Deluxe Sport Coupe        (Topic#349880)
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
06-23-20 10:44 AM - Post#2797013
    In response to tommy49
Nice
Bill Wilson 50 styleline deluxe 2 door sold,- 51 styleline Deluxe 2 door ,'56 235 with dual carter webers on an Offenhauser intake, Fenton headers, 56 chevy rear end and 700R4 transmission.
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
06-25-20 05:36 AM - Post#2797135
    In response to one4dad
Thanks, Bill!
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
tommy49
tommy49
Reg: 09-28-12
06-27-20 11:38 AM - Post#2797307
Been working on stiffening the condenser brackets and sharpening up my tig skills. Here's the first one. Now that I figured out the process, the other three should go faster.
Attachment: condenser_brackets_1.JPG (160.37 KB) 9 View(s)
Attachment: condenser_brackets_3.JPG (170.41 KB) 9 View(s)
Attachment: condenser_brackets_4.JPG (175.02 KB) 9 View(s)
Attachment: condenser_brackets_2.JPG (168.57 KB) 9 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
06-27-20 12:26 PM - Post#2797311
Forgot one:
Attachment: condenser_brackets_5.JPG (150.75 KB) 9 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
07-07-20 08:07 AM - Post#2798124
As usual, I couldn't leave the condenser brackets alone. First, I extended the lip past the first screw, that really stiffened up the brackets. The next thing I did was weld nuts on the brackets. I got tired of messing with washers & nuts on the backside of the brackets , so the welded nut took care of that issue. While I was at it, I welded in 2 nut plates for the horns. Easy Peasy!
Attachment: condenser_brackets_6.JPG (175.62 KB) 9 View(s)
Attachment: condenser_brackets_7.JPG (170.96 KB) 8 View(s)
Attachment: horn_nut_plate.JPG (168.37 KB) 8 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
07-07-20 08:10 AM - Post#2798127
Now, I can paint the parts and get started on the radiator mods.
Tommy
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
07-07-20 08:13 AM - Post#2798128
Sweet to say the least. I wish I had developed your skills.
Do you have a goal to start up and drive?
Bill
tommy49
tommy49
Reg: 09-28-12
07-07-20 08:49 AM - Post#2798131
I thought I would be up & running by now, but I've spent more time on the small details than I should have, but, the small details are what I like doing. If I thrashed just to get the car on the road, I know I'd be disappointed that I didn't do the work I'm capable of doing. Those details make my car my car, make it stand out.
Tommy
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
07-07-20 09:36 AM - Post#2798134
:laugh :
07-07-20 10:26 AM - Post#2798141
Great work.Tommy.
29-41, 42-48, 49-54 Moderator
tommy49
tommy49
Reg: 09-28-12
07-07-20 10:58 AM - Post#2798146
Thank you!
Tommy
Nite Dragon
Loc: Orange Park, FL
Reg: 09-20-13
07-07-20 03:10 PM - Post#2798166
Great work as always Tommy. I feel the same way. I catch myself dressing up welds behind panels no one will ever see, but I know its there and will haunt me.
tommy49
tommy49
Reg: 09-28-12
07-07-20 03:42 PM - Post#2798169
    In response to Nite Dragon
Yep, Kat says I get too anal on the small stuff no one will see. Right now I'm looking at filling the 8 unused radiator mounting holes because they're there.
Tommy
tommy49
tommy49
Reg: 09-28-12
07-12-20 12:39 PM - Post#2798532
Had a chance to get in the shop today, so I made the LS steam port bung and welded it on the radiator.
Attachment: LS_steam_port.JPG (163.35 KB) 9 View(s)
Tommy
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
07-13-20 06:21 AM - Post#2798578
One thing about being a little too anal about the small stuff is that it may help to avoid future drivability, and dependability problems. I say keep up the good work and attention to details.
1950 Fleetline, 355 TBI, mild cam, 700R4, 3.73 posi rear Blazer axle, MII front. Remote door and trunk locks, GM cruise control, A/C,
tommy49
tommy49
Reg: 09-28-12
07-13-20 07:04 AM - Post#2798579
    In response to johnwd98
Thanks for the encouragement, John.
Tommy
nightliner
Loc: Hannover, Germany
Reg: 08-23-16
07-14-20 03:19 AM - Post#2798646
Nice Work, thanks for Detail picturen
thats great for me
Enjoy every ride, every day
tommy49
tommy49
Reg: 09-28-12
07-14-20 03:27 AM - Post#2798647
    In response to nightliner
Thank you for the compliment, Bjoern, and I'm happy to see the pictures are being helpful.
Tommy
Edited by tommy49 on 07-14-20 03:31 AM. Reason for edit: No reason given.
tommy49
tommy49
Reg: 09-28-12
07-19-20 01:49 PM - Post#2799078
Wrapping up the cooling system for now. Everything fits great and I also made some hardware changes. I used button bolts for the condenser, horns, and radiator and I also used u-nuts on the radiator, eliminating all the washers & nuts. Very clean. Another thing I did to clean up the front end was reroute the headlight harness under the electric fan and added a weather pack connector. Almost forgot, I put a hole in the radiator core support for the condenser lines. For now, it's time to get back to work on the the firewall.
Attachment: 4.8_cooling_system_10.JPG (170.02 KB) 9 View(s)
Attachment: 4.8_cooling_system_11.JPG (158.87 KB) 9 View(s)
Attachment: front_end_wiring_1.JPG (151.13 KB) 9 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
07-21-20 08:29 AM - Post#2799154
Before I pull the steering column, I wanted to make a new shift bracket so I can try to use the shift linkage I had on the 700r4. The column I have came from Walton's as a kit, but it's longer than I would have liked, and the supplied shift bracket is unusable for what I want to do, so I made a bracket. It's just a prototype and I won't know how it'll work until the engine & trans are back in, but it's a start.
Attachment: column_shift_bracket_1.JPG (153.65 KB) 8 View(s)
Attachment: column_shift_bracket_2.JPG (170.42 KB) 8 View(s)
Attachment: column_shift_bracket_3.JPG (162.57 KB) 8 View(s)
Tommy
Edited by tommy49 on 07-22-20 06:27 PM. Reason for edit: No reason given.
tommy49
tommy49
Reg: 09-28-12
07-31-20 12:18 PM - Post#2800002
I've had this issue of the firewall mounted brake booster boot being too short to seal the mounting plate hole and I couldn't come up with a suitable fix, until now.
I bought a motorcycle boot, cut the big end off, cut the small end off the booster boot,
and glued them together.
The booster is offset from the plate hole, so I added a piece of tubing to make up the difference.
Attachment: brake_booster_boot_1.JPG (161.12 KB) 4 View(s)
Attachment: brake_booster_boot_2.JPG (162.36 KB) 4 View(s)
Attachment: brake_booster_boot_3.JPG (164.84 KB) 4 View(s)
Attachment: brake_booster_boot_4.JPG (167.32 KB) 4 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
07-31-20 12:23 PM - Post#2800003
And the result is a perfect fitting booster boot.
Top view:
Bottom view:
Attachment: brake_booster_boot_5.JPG (158.89 KB) 4 View(s)
Attachment: brake_booster_boot_6.JPG (150.92 KB) 4 View(s)
Tommy
07-31-20 02:49 PM - Post#2800023
You guys always amaze me the way you can come up with a solution. I very seldom can figure out something that will work.
Execution time: 0.406 seconds.   Total Queries: 25   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:43 PM
