 Page 6 of 6 « First<3456
Username Post: Tommy49's 1949 Deluxe Sport Coupe        (Topic#349880)
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
03-04-20 04:23 PM - Post#2787942
    In response to tommy49
And here's one with it installed:
Attachment: fuel_filter_4.JPG (146.09 KB) 4 View(s)
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
03-14-20 02:44 PM - Post#2788645
I haven't checked back here in a while. You are moving right along. All first class work.
Cheers!
Dean50
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
03-16-20 07:05 AM - Post#2788754
Beautiful work
52 Styleline Fourdoor 62 235 PG
tommy49
tommy49
Reg: 09-28-12
03-16-20 09:20 AM - Post#2788777
    In response to gcrkfrd
Thanks for the compliments, guys! Finally wrapped up the exhaust, fuel hoses and rear brake line. I moved the brake line from the right side to the left side, so I had to rework the rear axle brake lines. Felt like I've been camped out under the car for weeks!
Here's a few pictures:
Attachment: new_dual_exhaust_11.JPG (157.07 KB) 2 View(s)
Attachment: new_dual_exhaust_12.JPG (142.98 KB) 2 View(s)
Attachment: new_dual_exhaust_13.JPG (153.39 KB) 2 View(s)
Attachment: new_dual_exhaust_14.JPG (145.8 KB) 2 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
03-16-20 09:23 AM - Post#2788778
Here's a couple more from that set:
Attachment: fuel_hose_bracket_above_rear_axle.JPG (144.49 KB) 2 View(s)
Attachment: fuel_hose__filter___brake_line.JPG (143.19 KB) 2 View(s)
Attachment: rear_axle_brake_hose_braket.JPG (141.81 KB) 2 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
03-19-20 10:04 AM - Post#2788973
I played around with some detail work on the front body supports. I removed part of them to make clearance for the exhaust manifolds, but that left them looking hacked up. So, I cut off the excess bracket off the firewall, and used the inner lip to make a finished edge. I only did part of the right side, I'll finish both when the engine comes out.
Attachment: body_support_rework_1.JPG (155.89 KB) 0 View(s)
Attachment: body_support_rework_2.JPG (143.21 KB) 0 View(s)
Tommy
Eyetech
Eyetech
Loc: Finland
Reg: 11-29-01
03-20-20 11:56 PM - Post#2789095
Interesting project.
I think you should change the headers for hugger type, you don't have much room for the steering lingage. Am I right?
Could you post picture of engine clearence to firewall?
I'm doing LM7 swap (waiting the engine) and was wondering those vertical supports, remove or not...
Chevrolet '52 Custom Project Blue-Eye
Chevrolet '52 Coupe Ute Chevy Ute
Chevrolet '51 Sedan Delivery
www.eyeballproducts.com
tommy49
tommy49
Reg: 09-28-12
03-21-20 02:30 PM - Post#2789154
    In response to Eyetech
I'm waiting for the shafts and u-joints to come in, then I'll see what I need to do. This is a budget-build, so there's not a lot of money to toss at every problem. Always looking for a work-around. Here's a couple pictures of my clearance.
Attachment: left_side.JPG (161.12 KB) 1 View(s)
Attachment: right_side.JPG (154.8 KB) 1 View(s)
Tommy
Eyetech
Eyetech
Loc: Finland
Reg: 11-29-01
03-23-20 07:35 AM - Post#2789303
Thanks Tommy.
It seems, that I've to cut those vertical supports away. So tight, so tight...
tommy49
tommy49
Reg: 09-28-12
03-23-20 08:05 AM - Post#2789306
Everything's tight on these swaps. We set the front clip on to mark up where to cut the wheelwells for spring tower clearance and figure out what to do with radiator cooling. I don't like to hack things up unnecessarily. When I do have to hack, I try to give it a "finished" look.
Tommy
Eyetech
Eyetech
Loc: Finland
Reg: 11-29-01
03-23-20 01:36 PM - Post#2789327
Yeah I know.
I've done LS1 swap for my '52 (Blue-Eye), now putting LM7 to Sedan delivery…
About the radiator, I use 2000 Camaro radiator for Blue-eye. I tilt it backward and it fits, even with Camaro air filter case
In sedan delivery I'm gonna use 2004 Silverado radiator.
tommy49
tommy49
Reg: 09-28-12
03-23-20 05:31 PM - Post#2789339
I have a stock-style aluminum radiator and will probably go with a shrouded pusher fan. Minimum modification.
Tommy
tommy49
tommy49
Reg: 09-28-12
03-26-20 05:21 AM - Post#2789484
I put the front clip up on saw horses and started to mod the inner panels to clear the MII spring towers. The right side was easy, but the left side needed more work. I decided it would be easier to just fill in the whole opening, then cut out what I needed. A little more finish work today, then on to something else.
Attachment: inner_panel_spring_tower_mods_1.jpg (154.92 KB) 0 View(s)
Attachment: inner_panel_spring_tower_mods_2.jpg (156.29 KB) 0 View(s)
Attachment: inner_panel_spring_tower_mods_3.jpg (160.84 KB) 0 View(s)
Attachment: inner_panel_spring_tower_mods_4.jpg (154.81 KB) 1 View(s)
Tommy
Execution time: 1.453 seconds.   Total Queries: 23   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:19 AM
