 Page 2 of 2 <12
Username Post: Vintage air        (Topic#349698)
Swifster
Loc: Bradenton, FL
Reg: 05-26-18
10-11-18 03:54 PM - Post#2748458
    In response to junky
Vintage Air did a presentation at Ididit in MI. The real difference between R-12 and 134a systems is the condenser. R134a isn't as efficient as R-12 and requires more tubes and fins in the condenser. Give them a call and explain what you are looking to do and they should be able to point you in the right direction.
Tom
1963 Chevrolet ?
$121.00
64ausbelair
64ausbelair
Loc: Australia (QLD)
Reg: 10-26-06
10-12-18 12:45 AM - Post#2748481
    In response to Andy4639
Hey Andy. As Junky says. All vintage air stuff is 134a I have gone with a 24 x 14 x .83 condenser. The one they use for the sure fit system is 22 x 14 x .83. That size isn’t readily available here in oz. I ended up going with the slightly larger one. I don’t want to let too many secrets out but I think this system is going to look pretty trick. I’m adapting some 61 Pontiac ac controls and vents etc so that it all looks period for our rhd cars. I’ll post some progress pics over the next couple of weeks.
Cmb62
Loc: Sydney, Australia
Reg: 04-28-17
10-13-18 01:57 AM - Post#2748551
    In response to 64ausbelair
That’s cool Jason. Looking forward to updates and pics
Go with the flow
vintage air tech
Loc: San Antonio
Reg: 04-27-18
10-16-18 10:39 AM - Post#2748836
The General rule of thumb is, as long as the condenser was designed for R134a going larger is the best option. The 22" works well but the 24" will shed more heat. Keep us posted on the build pics we love to get photos of what you guys are cooking up!
Performance First
64ausbelair
64ausbelair
Reg: 10-26-06
11-13-18 11:53 PM - Post#2751337
    In response to vintage air tech
Hi all. So I’ve managed to get my ac up and running. I used a gen 2 super unit. I can tell you for such a large looking car I spent a lot of time up under the dash making sure everything would fit. I ended up sourcing a 61 Pontiac heater control panel and adapted the switches, thermostat and pot slider (for the heater valve) to that old unit to make it look like it’s meant to be there. I also thought I’d be super authentic and sourced two 61 Pontiac dash ball vents. Turns out that even though the Australian dashes are from a 61 Pontiac the ends of the dash have a different profile. So the vents I sourced aren’t quite going to fit. So I have a bit of work to do with the face vents. I’ll post some pics once I have those fitted up nicely. All in all I’m pretty happy with the unit. It certainly pumps out some cold air. I have turned the old heater control levers into the two floor vents and made a new blank polished ally facia to replace the old heater control one. I still have to do something with the glove box also. The unit protrudes about half way across where the glove box sits. I’ll cut the glove box down and make it fit. The old radio I had to slice a tad off the back of that also. It didn’t work but I like to keep things inside looking period and original. I did use a 2 inch larger condenser than the usa left hand drive ready made kit. I used a billet industries compressor bracket. Although they’re exy it was worth it. I’ve made brackets before for certain things and there is a lot of back and forth measuring and cutting and modifying. So well worth it in my books. If anyone is interested I could put together a list of parts used. I got my hose fittings locally from Ashdown Ingram for anyone going down this path. Had a local guy crimp all the hoses and gas the system for me after I had fit everything. So anyhow I’ll try this imgur link or a few pics to have a look. Hope it works.
https://imgur.com/gallery/8HJ1aaX
Jason.
Cmb62
Reg: 04-28-17
11-15-18 02:35 AM - Post#2751448
That looks pretty good Jas. I’d be interested in what parts you used if possible.
Go with the flow
64ausbelair
64ausbelair
Reg: 10-26-06
11-17-18 03:35 AM - Post#2751584
    In response to Cmb62
The main hardware I used was.
Gen 2 super. 61005-vzu-a
Compressor va047001-suq
Bracket bs10421 ( billet specialities)
Drier with binary switch 07322-vuc
4 diamond bulkhead VA388600-MBA
Condenser 03263-Vuc 14x24
Controls VA49110-SHQ
So with all these parts I ended up manufacturing my own condenser and drier brackets. I had previously bought two new replacement firewall bulkhead plug/sockets from summit racing (American auto wire plugs ) and added the wiring in one for the main power supply and the binary/conprsssor wire. Inside the car I disassembled the old radio took out some of the backend garbage and remade the case to shorten it down. It took a bit of courage on my behalf to do this because I hate knowing I’ll never be able to have that working again. It wasn’t working in the first place so that helped my decision. I made my own brackets to mount the evaporator unit up under there. All I can tell you is one goes into a nutsert into the plenum chamber and two angle type brackets mount with counter sunk bolts to the under side lip of the dash. As I said in my other post, the glove box is still in need of some trimming down. About half to be axact.
The hose and the fittings were all from Ashdown Ingram just because I couldn’t get VA stuff in exactly what I needed. The controls were the interesting part. I started with a va control unit and just took it apart. I had to start with that just to see how the switches worked and the value of the heater potentiometer. I now know how they all switch etc. and could potentially use generic switches and whatnot from an electronics shop. I got a 61/62 Pontiac heater control unit and went to town on it. Without too much detail on modifications to get it all working from the old school unit. I can say that the fan switch and the heater potentiometer are mounted directly to the unit. And the thermostat and vent control switch are mounted remotely and operate via cables.
The dash/face vents I’m still working on. I have a few ideas there to keep it looking original and period. I know there are options for those from vintage air but I’m not completely sold on those just yet. I think I’ve covered most things. It’s certainly custom and one of a kind. And the main part is it’s out of sight !!!! Oh and it certainly has enough cooling for QLD heat.
Jason.
Cmb62
Reg: 04-28-17
11-17-18 02:51 PM - Post#2751633
Thanks for that Jason, interesting read. My 62 is radio delete, so won’t have to worry about that and glad to hear you are happy with how it cools. That has been one of my concerns.
I just might have to give it a go myself.
Go with the flow
Aussie_Chevy_Nut
Aussie_Chevy_Nut
Loc: Australia
11-17-18 11:53 PM - Post#2751674
Hi, not sure if you are interested, but I have a number of original '62 Impala Air Con parts that I was collecting some years ago to instal in my '62 Convertible but never did because of the difficulty. These parts are for the US style dash but converted to RHD at the time.
Cheers,
John, Sydney
Cmb62
Reg: 04-28-17
12-16-18 10:42 PM - Post#2754751
A few questions....sorry if they seem silly, but just been thinking....
So adding the condenser to the front of the radiator means more air needs to be passed/ sucked thru that area to be able to cool sufficiently.
Are the stock radiator (which I think is a 2 row core?) and 4 blade fan sufficient?
Your Fan looks to be a clutch type? Is that also a better option?
I’m also still running a Generator, but looking to replace with an alternator, any particular ampage I should look at as a minimum to run ac? I don’t have a radio.
Also do the hoses on a stock ac car run thru the fire wall or are they directed down around the guards near the bonnet hinges and in thru the kick panel? I seem to recall seeing something like that?
I think that’s all for the moment.
Thanks Chris
Go with the flow
64ausbelair
64ausbelair
Reg: 10-26-06
12-17-18 02:04 PM - Post#2754847
Thanks Chris
Hi Chris.
My radiator is the stock unit that came on the 283. It has been reconditioned though. The fan is also the stock fan that came on the engine. My engine isn’t over the top in hp but Is still pretty healthy with the aluminium heads and mild cam installed. Believe it or not I had to run a hotter thermostat to get the temp siting nice. When I took my daughter and friends to their formal I was sitting in traffic at one point it was a sunny hot day and the temperature did rise. But it still didn’t get to the point where I was worried.
As far as your alternator goes. I’d have to check mine again but I think it may be an 80A. The circuit breaker that comes with the vintage air setup is 30A for reference. Although it probably doesn’t pull 30A. That coupled with the rest of your car circuits. I’d probably be looking at a decent alternator size. 55 60 may be ok but boarder line ?
I’m not sure about the original ac lines. Coming through the kick panel might be kinda tight. I’m not sure. The vintage air bulk head was neat enough for my liking. The only complaint I have with the bulk head, is the heater lines. It’s not easy finding a fitting here in Australia believe it or not. You need a #10 o-ring fitting with a (5/8 from memory ) barb. Not easy to find.
Can you show me a close up picture of the edge of your dash.? Where it meets the pillar. I think these Pontiac vents I have may for a 61 62 dash.
Jason.
 Page 2 of 2 <12
Execution time: 0.107 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:44 PM
