Username Post: 65 impala dash harness        (Topic#349435)
Tiny1000
Tiny1000
Reg: 01-20-15
01-31-18 05:31 PM - Post#2722902
Donny sorry another question cluster harness and tach harness both have instrument lights what do you suggest I use also just wondering why the brake warning light bulb has 2 wires
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
01-31-18 06:31 PM - Post#2722911
    In response to Tiny1000
Because one is 12v ignition and the other is the ground that goes down to the switch. The tach harness was a stand alone harness and could be installed in a Biscayne with no light in that pod, so it came with lamps. Just use the ones from the cluster and don't plug the gray wire from the tach harness into the fusebox, then tape the sockets back.
Donny
Tiny1000
Tiny1000
Reg: 01-20-15
02-01-18 04:13 AM - Post#2722957
    In response to aawtech
Thank you
Execution time: 0.183 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:20 PM
