Username Post: 97 k1500 binds up when starting        (Topic#349395)
Fish22
Reg: 01-29-18
01-29-18 04:48 PM - Post#2722620
I have a new direct drive starter, new distributor, and a new battery. Cold starts fine but after it gets up to temp and you shut it off for 10 minutes or so it binds up and tries to kick back when starting. Set the time with computer when we put the new distributor in. It was at 0. Cold cranks fine and starts fine if you start it back immediately after shut off but let it set for a few minutes and I have problems. Any help greatly appreciated.
runamukker
Reg: 01-01-18
01-29-18 08:30 PM - Post#2722658
    In response to Fish22
Does the truck have headers?
'92 K1500 Blazer Z71 350TBI 700R4 , 253,000 miles
'94 C1500 Cheyenne WT 350TBI 4L60e , 565,000 miles
Fish22
Reg: 01-29-18
01-30-18 07:44 AM - Post#2722685
    In response to runamukker
No
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-30-18 09:37 AM - Post#2722699
Not sure what headers would have to do with it. It sounds like a bad starter to me. Was it a remanufactured starter?
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
runamukker
Reg: 01-01-18
01-30-18 10:15 AM - Post#2722702
    In response to bowtie44s
Headers can heat up a starter and make it not wanna crank until it cools.
I wonder why Fish22 added a new direct drive starter, new distributor, and a new battery. Was there a problem before the new parts?
Fish22
Reg: 01-29-18
01-30-18 02:18 PM - Post#2722737
New carquest starter
Fish22
Reg: 01-29-18
01-30-18 04:38 PM - Post#2722763
Yes. When it got up to temp it was really hard to turn over. It had a new starter on it, the bigger style and it was really close to the exhaust. It did have a heat shield on it though. I had a mechanic look at it and he suggested a smaller and stouter direct drive type. That did help but didn't eliminate the problem.
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
01-30-18 07:11 PM - Post#2722781
2 things I'd try,
1) Turn the motor over twice by hand with a big wrench/socket when it is cold. Then do it again after it is warmed up. If there is little difference, then yes it is a starter system issue. If there is a big difference, you need to look elsewhere.
2) Try pulling the fan belt off and starting it when it's hot. Could be a pulley or accessory seizing up when it's warm.
-91 Sierra C2500, now K2500
-81 Chev K20
Fish22
Reg: 01-29-18
01-30-18 07:26 PM - Post#2722782
    In response to stumppuller
Will do. Thanks
Execution time: 0.171 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:50 PM
