Username Post: Kenmore oven        (Topic#349143)
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
01-13-18 08:10 AM - Post#2720936
The stove stopped heating in the oven. Tis an electric Kenmore.
Any pointers?
I was thinking that I should tear it apart and check for continuity in the heating element.
The broiler still heats....which may or may not matter, 'cuz if there are relays and other gizmos involved, I am assuming that each circuit would be totally separate (or enough separate that it wouldn't matter).
Edited by Stinky on 01-13-18 08:13 AM. Reason for edit: No reason given.
Lorence
Reg: 05-23-17
01-13-18 01:56 PM - Post#2720952
    In response to Stinky
Fuses? If they are still using them on stoves. Next step voltmeter and work your way back from the element to the switch(s)
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
01-20-18 06:52 PM - Post#2721635
    In response to Lorence
I pulled both elements.
The broiler (which works), reads 15-16 ohms. The oven reads 14 ohms....when you swap them, it still doesn't work.
It has juice to the the element.
The control panel is all digital push button...that is one of my suspects.
But, I am gonna pull the back of the stove off today.
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
02-05-18 10:35 AM - Post#2723421
check the automatic on off feature for timed cooking. on occasion it gets bumped or reset when cleaning and that will stop the manual on off operation.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
DECEASED
02-07-18 09:03 AM - Post#2723630
  • Stinky Said:
....It has juice to the the element....
Does this mean you are seeing 240V at the terminals of the element connector or socket? If yes, is the element plugged in or connected when you are taking this voltage reading?
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
12-08-18 07:24 PM - Post#2753922
I changed the control panel and it is still in use, months later.
Execution time: 0.372 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:21 PM
