Username Post: goodwrench 350 into 84 impala        (Topic#348751)
VRdrift
Reg: 12-18-17
12-18-17 02:42 AM - Post#2718332
hey guys new to the forum from Australia, just want to confirm if a crate engine i have casting 10066036 will be a direct swap out from the factory 305, I want to put my original carb an intake etc onto the new motor, thanks
DECEASED
12-18-17 12:54 PM - Post#2718358
    In response to VRdrift
There are two potential compatibility issues you need to check out before you lay down your money - the heads and the crank flange.
If the crate engine uses center bolt valve covers, your intake manifold won't bolt up to those heads. If it has a one-piece rear crankshaft seal, your flywheel/flexplate won't fit the crank flange bolt pattern.
I can't tell you how to identify these issues without actually looking at the engine. If you can't tell by looking, ask the vendor. If the vendor can't answer these questions, you might be better off shopping elsewhere.
VRdrift
Reg: 12-18-17
12-18-17 02:19 PM - Post#2718364
Thank you Ray, it’s not a center bolt motor I think, I’m going to look at it later, and I’ll grab a pic of the crank seal of that helps? it’s a second hand motor, it was used only very briefly
DECEASED
12-18-17 04:36 PM - Post#2718370
The crank flange is less of an issue than the heads. Assuming you have an automatic trans, the later type flexplate isn't expensive or difficult to find. For that reason, the flange shouldn't be a deal breaker. IMO, the one-piece seal is a better design anyway.
VRdrift
Reg: 12-18-17
12-18-17 04:51 PM - Post#2718373
Cool, cheers yea I’m told the heads are the earlier type, (bolts on the sides,)but since I know little of these I’ll post some pics up later to be absolutely sure, yes it’s an auto, and the car is almost stock, only reason I want to swap to this engine is because I’m getting it for a lot cheaper than I can rebuild the 305 for,
VRdrift
Reg: 12-18-17
12-19-17 10:25 PM - Post#2718508
i cant upload pictures as my image hosting site does not recognise this site, but its a gen 1 style engine with the 2 piece seal, a guy on another site is telling me my cc quadrajet will not work on the 350, is there any truth to that?
DECEASED
12-19-17 10:55 PM - Post#2718510
Does cc mean computer controlled? If yes, I honestly don't know enough about that to answer. What does your other site guy say won't work? I mean, is it a calibration issue or what? Also, does the finished installation have to pass an emission test? If yes, your guy might very well be right.
VRdrift
Reg: 12-18-17
12-20-17 02:32 AM - Post#2718513
yes computer controlled, there are no emissions tests at all here, but im being told dont bother with it all, its cheap enough to convert it to a regular carb and distributor
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
01-03-18 02:35 PM - Post#2719901
CCC Q-Jet will work just fine on a 350. May need some mechanical adjustments to the mixture control system and a better set of secondary rods (Would find some DR's to start on a lower alpha hanger. (B-H hanger) but if the system is correctly operating and in good shape it will run and drive as if it still had the 305 under it driveability wise and just have the added punch of the 350 when you are into the throttle. I have had one on both a 403 Oldsmobile that went in place of a 307 in a 1988 Cadillac and a 400 HP 383 Chevy in a 1985 Elcamino.
Edited by 1983G20Van on 01-03-18 02:37 PM. Reason for edit: No reason given.
Execution time: 0.091 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:21 PM
