Username Post: 8 gauge wire be ok for 140amp alternator?        (Topic#348655)
asahi1234
Reg: 06-19-14
12-12-17 12:39 AM - Post#2717648
I have a 140amp 10si alternator. Will a 8 gauge wire be enough? I need to order a kit for my 62 impala.
Donny
American Auto Wire - Site Sponsor
Loc: Bellmawr, NJ
Reg: 09-11-06
12-12-17 05:44 PM - Post#2717734
    In response to asahi1234
Your alternator will only charge what you car uses. 1 in 1000 cars will ever use 140 amps. Most cars that are pretty loaded (dual fans, high output ignition, A/C, etc.) will only use 90-100 amps. So, unless the car you are building will ever use the full 140 amp capability, you'll be fine, yes.
Donny
Execution time: 0.247 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:50 AM
