Username Post: Brakes        (Topic#348492)
bigal6947
Loc: Windsor, Missouri
Reg: 11-30-12
11-30-17 04:49 PM - Post#2716450
Have put 55 Chevy that I just put disk brakes on all 4 corners. Have new master and all new lines/hoses. There are times when pedal goes almost all way to floor, car stops but not abrupt. It will do it after sitting for awhile after driving or when I take it out of garage. Thinking about putting a one way valve between master and back brakes so fluid will be there and not take to much pressure. Any help would be appreciated.
11-30-17 06:02 PM - Post#2716461
    In response to bigal6947
Lotta things can cause this, air in the system, soft/swelling hoses, improperly installed or designed caliper brackets, wrong master or proportioning valve for four wheel discs, are some possibilities.
11-30-17 06:10 PM - Post#2716465
You can't use a check or residual vakve on disc. There is no return spring, so any pressure will keep the pads in contact with the rotor.
What rear calipers? If the emergency brake is adjusted incorrectly on some calipers, the pads will be too far from the rotor, especially after hand brake use.
11-30-17 06:39 PM - Post#2716468
    In response to acardon
Good point on the e brakes built into the rear calipers, they were somewhat problematic when I worked for Cadillac, especially if not used occasionally to keep them adjusted.
56Rat
Reg: 06-23-19
07-04-19 08:36 PM - Post#2769961
Sounds like you may still have some air in the system or a possible small fluid leak.
07-05-19 05:44 AM - Post#2769975
    In response to 56Rat
After 2 years, I hope not.
Beltfed
Reg: 10-04-18
07-05-19 07:46 AM - Post#2769977
They do make residual valves for disc brakes. The are set at two pounds. Drums valves are 10 pounds. If your master cylinder is under the floor and below the brakes, they are suggested. Check Master Brakes web site.
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
07-10-19 01:15 PM - Post#2770394
Original post, 11/30/17,
New reply, 07/04/19,
I say some body hand me another cold one!
I sure hope the original poster has a follow up soon!
I'll take the time to go through the run down.
wonder what he found?
is his internet that slow?
Hopefully he posts what the issue was in the next 50 years, cause after that I won't be around to see it.
Some are thinking did he sell the car?
some may be thinking, " I sure hope he is still not bleeding them".
gud lawd that's a lot of brake fluid!
I know a lot of people have seen the other post about the 12 driving tips.
I saw that and I immediately thought you have got to be kidding me.
I don't even want to go any further about it or even address it but it looks like it has a link to something that should not be here.
I'm hoping Tony see's that an addresses that BS.
VC56S 2 door Sedan, 39 Years
Edited by Bad56Sedan on 07-11-19 05:14 PM. Reason for edit: I can't spell
Execution time: 0.161 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:38 PM
