Username Post: 87 IROC Z28 ..lack of spark        (Topic#348474)
0utlaw
0utlaw
Loc: US East Coast
Reg: 09-10-02
11-30-17 03:23 AM - Post#2716356
Good morning.
Just arrived here in Florida 2 weeks ago. Last year, the motor made 3 turns and fired right up and ran good.
This year, not that lucky. Camaro does not start after sitting 6 months. I use Stabil in gas. Ran great before I left. Has had new plugs and wires 2k ago. Cap and rotor look good. This is a factory unmolested 305 tpi with all emission equipment.
Here are the parameters;
Battery is charged. Motor spins well. Fuel pump turns on and exhaust smells some gas. Does not fire up on starting fluid. Distributor rotor is turning and there is 12v at the coil. Just replaced ignition module and coil--both were original. Timing light shows no spark at coil terminal while cranking. All fuses in fuse block under dash are good.
I made it a point not to keep cranking the motor.
Any guesses would be appreciated...thanks in advance.
11-30-17 05:20 AM - Post#2716363
    In response to 0utlaw
Coil in cap, Gm hei? Got 12v cranking also?
0utlaw
0utlaw
Loc: US East Coast
Reg: 09-10-02
11-30-17 06:27 AM - Post#2716366
Separately mounted coil from factory. Factory ignition with smaller distributor with magnetic internal induction coil and ecm. I have not checked cranking voltage at coil, but will.
Good tip. Thanks
0utlaw
0utlaw
Loc: US East Coast
Reg: 09-10-02
11-30-17 09:40 AM - Post#2716399
Cranking voltage at coil 9.80 volts. Timing light still shows no spark.
11-30-17 03:50 PM - Post#2716444
This may help. http://easyautodiagnostic s.com/gm/4.3L-5.0L-5.7L/d...
0utlaw
0utlaw
Loc: US East Coast
Reg: 09-10-02
11-30-17 04:50 PM - Post#2716451
Thanks. This is very helpful. I'll check it out.
Execution time: 0.779 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:46 PM
