Username Post: Frame swap/chassis swap        (Topic#348280)
Travlr
Reg: 11-19-17
11-19-17 11:18 AM - Post#2714941
I'm splicing two frames together to get a longer wheel base. The front will be from a 1995 Caprice and the other is as yet unidentified. I could use another Caprice sedan, but I need a side fill fuel tank so am wondering if the wagon has the same frame dimensions? So far I haven't been finding any good frame specs for the mid-nineties Caprice, sedan or wagon. I know the track is different between the two, but what about the frame width? Also, is the Buick Roadmaster using the same frame? Any knowledge would be greatly appreciated.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
11-19-17 05:01 PM - Post#2714980
    In response to Travlr
93-96 caddy fleetwood is 121.5 wb
Travlr
Reg: 11-19-17
11-19-17 06:23 PM - Post#2714990
    In response to junkman104
Thanks for the info. Hard to find a Fleetwood that's affordable and there are other issues as well. Still hoping someone has a good link to frame widths for Caprice sedan and wagon. Also, I think Buick Roadmaster would be the same frame.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
11-20-17 06:40 PM - Post#2715130
Roadmaster sedan frames are identical. Wacha doing with it?
threeimpalas
Loc: Central Iowa
Reg: 02-21-02
12-15-17 08:25 PM - Post#2718076
The B-body wagons have a slightly wider frame and axle at the rear than the sedans. Same wheelbase, though.
Sedans: Caprice, Impala SS, Roadmaster
Wagons: Caprice, Roadmaster, Olds Custom Cruiser
The Fleetwood is a D-body.
'58-62s and 348/409s
Edited by threeimpalas on 12-15-17 08:26 PM. Reason for edit: No reason given.
Execution time: 0.088 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:30 AM
