 Page 9 of 9 « First<6789
Username Post: 1961 Impala build        (Topic#348225)
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
06-29-21 01:00 AM - Post#2822287
    In response to Spas602
On your intake, did you remove and clean under the heat shield?
I’d also suggest you block off the heat crossover under the carb, to prevent boiling of fuel, plus when you get there, you should use a phenolic spacer to also prevent heat transfer.
Keep up the good work.
Member #2194
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
08-10-21 06:30 PM - Post#2824908
    In response to DonSSDD
Thank you sir for your feedback. I notified my father to help keep an eye out for the spacer before starting it.
Found these revel mouldings from a swap meet guy. I definitely needed the side windshield trim.
Attachment: 968A45DA-0255-45DC-8A27-AC7F1FE38467.jpeg (415.18 KB) 1 View(s)
My CT Build Page:
https://bit.ly/3dAB7Wx
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
08-17-21 05:39 PM - Post#2825424
Got the 1960 348 engine back. Rebuilt to stock specs. .30 over on the pistons. Will update soon.
Attachment: 5DCD76F4-9351-4E93-97E8-53E3E44A8C27.jpeg (2.56 MB) 1 View(s)
Attachment: 18F6F267-7A7A-4983-92A9-1886263134B6.jpeg (438.49 KB) 0 View(s)
Attachment: CB67E286-1C18-4BB8-9C80-FF08AADF4294.jpeg (360.78 KB) 0 View(s)
Attachment: 0B4FF772-D7BA-4A84-82E0-AF9DE8A12960.jpeg (2.35 MB) 1 View(s)
Attachment: B1DD668B-73B3-492C-B3A1-32F11DFAD593.jpeg (3.05 MB) 0 View(s)
My CT Build Page:
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
08-18-21 06:58 PM - Post#2825512
Attachment: 488A5DA1-DD90-4605-A4D0-EB4658BE862D.jpeg (2.64 MB) 0 View(s)
Attachment: B285E76B-7ABE-46F9-BB0A-A877175C6F95.jpeg (3.41 MB) 0 View(s)
Attachment: 998A8CEF-A7F1-4E1A-8082-32F46ABBD9C2.jpeg (2.9 MB) 0 View(s)
Attachment: CA30F432-1095-4A81-8811-B53712F2F43C.jpeg (375.78 KB) 0 View(s)
Attachment: 435C1A65-327C-4455-B39B-CE6BB15D63FC.jpeg (326.59 KB) 0 View(s)
My CT Build Page:
Mercedes
Reg: 07-09-18
08-21-21 07:58 AM - Post#2825644
I always painted the engine in pieces, then assembled.
Also, I installed all of the core plugs after painting so that it had a nice finished look. No masking required.
327
Loc: Ontario , Canada
Reg: 02-09-21
08-21-21 06:39 PM - Post#2825673
327
Reg: 02-09-21
08-21-21 06:40 PM - Post#2825674
    In response to Mercedes
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
08-23-21 03:57 AM - Post#2825764
    In response to 327
Thanks for your feedback.
Attachment: C34A9EB6-4071-48E4-9DC9-2EFEE633385B.jpeg (379.51 KB) 0 View(s)
Attachment: DC052B7A-B6B9-4ABC-AD00-1345935523B9.jpeg (408.71 KB) 1 View(s)
Attachment: 8EBFECDB-EE66-4F05-BBC5-97FA75B446FF.jpeg (2.77 MB) 0 View(s)
Attachment: E5F0FA58-2B10-4C57-9C7D-55EFE961D699.jpeg (2.47 MB) 0 View(s)
My CT Build Page:
DonSSDD
DonSSDD
Reg: 08-21-01
08-23-21 04:31 AM - Post#2825767
Looks great- when do you fire it up? Will you dyno it befor the install?
Member #2194
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
08-24-21 04:10 AM - Post#2825837
Thanks for your feedback. I don’t have a dyno to run it on. I need to acquire a new original wiring harness and gauges before starting it. I’m also running the 4 barrel intake for now until I add the tripower later on.
My CT Build Page:
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
08-24-21 04:16 AM - Post#2825839
More progress on the 1961 impala 4 door. Added 5/16 gas tank sending unit and new filler neck hose. Also connected some linkages and radiator hoses.
Attachment: F001224B-3D6B-4630-97AD-34E5DB66829C.jpeg (495.56 KB) 1 View(s)
Attachment: B0710760-BEB0-431D-8828-9C71BE638BCE.jpeg (2.5 MB) 0 View(s)
Attachment: 21396E1D-DF11-4D60-8AF2-38CA46F99044.jpeg (2.77 MB) 1 View(s)
Attachment: 5700CCDA-5D7E-427B-87BD-EFFFE2DA5DE6.jpeg (432.64 KB) 0 View(s)
My CT Build Page:
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
08-24-21 04:27 AM - Post#2825840
If you are going to run tripower shouldn't you put in the 3/8" sending unit now? Would save you some trouble later.
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
08-24-21 05:29 AM - Post#2825843
    In response to turbo38s10
The 5/16th sending unit is for the 283 1961 4 door. I already installed a new gas tank, 3/8 fuel line, and 3/8 sending unit installed for the 348 1961 2 door.
Thanks for your feedback. I’m definitely addicted to working on both cars again.
My CT Build Page:
DonSSDD
DonSSDD
Reg: 08-21-01
08-25-21 01:19 AM - Post#2825920
The American Autowire is the best. They will also modify to suit changes like a mini hitorque starter or an alternator.
Member #2194
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
08-26-21 04:04 AM - Post#2825994
Thanks for your feedback. I added the original manifolds back on and intake manifold. I need to install the fuel pump push rod next.
Attachment: 953B06E3-122B-4B55-AA64-BD074E7F0EB2.jpeg (2.72 MB) 0 View(s)
Attachment: F51927A0-6E49-435A-86AD-934D2257CD17.jpeg (2.75 MB) 0 View(s)
Attachment: 95E16C0A-C7CA-4946-8224-C5D09D583732.jpeg (214.3 KB) 0 View(s)
Attachment: ADB32BD6-56E9-4997-BECD-245C507DC169.jpeg (237.98 KB) 0 View(s)
My CT Build Page:
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
08-29-21 06:28 AM - Post#2826195
Added harmonic balancer, fan pulley, and fuel pump. Also added gaskets to fuel pump and valve covers. I have to redo the oil pan gaskets as I over tightened one side.
Attachment: 44E8E344-7F10-4FA9-920B-8F2ABEA8E85C.jpeg (3.22 MB) 1 View(s)
Attachment: 2FBEBC48-9D68-4E45-92A0-C7779A9F20E4.jpeg (360.88 KB) 0 View(s)
Attachment: 581B2CEF-F006-47E1-814D-AED87B6A41D0.jpeg (3.14 MB) 0 View(s)
Attachment: ACEA4CD8-1900-4781-8C54-96CE3C8A3E06.jpeg (2.94 MB) 1 View(s)
My CT Build Page:
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
09-05-21 05:28 PM - Post#2826600
Got the motor back into the car.
Attachment: 06880ABE-2A64-48E0-8EEC-F048481B7FA3.jpeg (3.52 MB) 3 View(s)
Attachment: 3442F536-7ECD-4140-B192-58FDEB513F74.jpeg (376.57 KB) 0 View(s)
My CT Build Page:
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
09-14-21 03:59 PM - Post#2827085
Installed the carburetor and air cleaner. Installed mini starter. Added used fuel line to route to carburetor. Added points distributor. Placed new coil on intake manifold using original coil bracket and bolts.
Attachment: 0C4C7B6D-5F6A-417B-B883-2D0666E173CF.jpeg (3.61 MB) 2 View(s)
Attachment: BEBF2A4B-05EA-4C19-BA75-5C5CB6AD1B7F.jpeg (3.34 MB) 0 View(s)
Attachment: EE7DD6B8-96A3-4CD6-A15B-C873D37069D2.jpeg (2.97 MB) 0 View(s)
My CT Build Page:
8683jb
Reg: 09-06-13
09-14-21 04:34 PM - Post#2827089
That's super clean! Nice job!
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
09-21-21 02:14 PM - Post#2827626
    In response to 8683jb
Thank you for your feedback sir. I appreciate it.
My CT Build Page:
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
09-21-21 02:20 PM - Post#2827627
Added rebuilt 348 cast iron water pump dated 1958.
Attachment: BEB953B3-79A8-4880-8C94-DDCB84D59301.jpeg (3.62 MB) 0 View(s)
Attachment: 4738FDE9-2196-4882-927B-7279B77D9285.jpeg (2.45 MB) 1 View(s)
Attachment: 56C2237C-72DE-4AE6-932F-5E587A0B77DA.jpeg (418.97 KB) 0 View(s)
My CT Build Page:
DonSSDD
DonSSDD
Reg: 08-21-01
09-22-21 02:33 AM - Post#2827665
The pictures are perfect. You must be enjoying the restoration process, it is looking good.
Member #2194
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
09-23-21 03:59 AM - Post#2827751
Thanks for your feedback sir. I really do like this car a lot. With hard work, I’m making my dream a reality with rebuilding this car.
Added original 1963 clutch fan onto the water pump pulley.
Attachment: CF9E5614-5991-441D-A921-3EBEAC189928.jpeg (3.31 MB) 0 View(s)
My CT Build Page:
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
10-04-21 05:34 AM - Post#2828471
Got the front clip back onto the car. Placed front bumper on to hold for safe keeping.
Attachment: CFCA3072-A550-4751-8E75-C7922D326D99.jpeg (368.54 KB) 1 View(s)
My CT Build Page:
G. Baker
Loc: Ontario Canada
Reg: 12-18-15
10-04-21 11:19 AM - Post#2828488
That looks like a 5 year project. Fantastic effort.
I don't have the patience to do it.
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
10-05-21 07:34 AM - Post#2828549
    In response to G. Baker
Thank you sir for the feedback.
My CT Build Page:
Seon
Loc: Lake Camanche, CA
Reg: 07-14-02
10-21-21 05:14 AM - Post#2829569
Labor of love. Great restoration pictures.
Grats.
Execution time: 0.151 seconds.   Total Queries: 29   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:11 AM
