Spas602
"2nd Year" Platinum Supporting Member
Loc: Phoenix, AZ
Reg: 08-30-17
11-15-17 05:49 PM - Post#2714545
Posting for years to come. enjoy.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-15-17 05:53 PM - Post#2714547
In response to Spas602
Edited by Spas602 on 10-17-18 04:47 AM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-15-17 05:55 PM - Post#2714548
Edited by Spas602 on 11-15-17 05:57 PM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-15-17 05:58 PM - Post#2714551
Edited by Spas602 on 10-17-18 04:48 AM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-15-17 05:59 PM - Post#2714553
Edited by Spas602 on 11-15-17 06:01 PM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-15-17 06:01 PM - Post#2714554
Edited by Spas602 on 11-15-17 06:02 PM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-15-17 06:03 PM - Post#2714556
Edited by Spas602 on 11-15-17 06:05 PM. Reason for edit: No reason given.
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
11-16-17 03:55 AM - Post#2714597
Nice project, except the transmission, needs to use 3 pedals.
Is that chrome paint on the rear axle?
Looks like pretty solid car you started with and a 348 tri power, you have good taste.
A Caddie and 3 Chevies, how many more projects do you have?
Member #2194
Edited by DonSSDD on 11-16-17 03:56 AM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-16-17 04:49 AM - Post#2714602
In response to DonSSDD
Transmission was a "smoke em' if you got em" thing. I wanted to go with a 350 turbo but only had the th400 available.
Rear end came off a 63 convertible, it is chromed. I also had chrome suspension but I sold before this project. I honestly wanted the rear end original with posi. But that's after I get this running.
Thanks for your feedback, the 64 ss does have 4 speed on the floor
junky
Loc: Northeast CT
Reg: 06-27-10
11-16-17 10:42 AM - Post#2714649
Is the 4 door a parts car? I like the Caddy in the picture, and would like to see some pictures of it also. Does it have a 3 piece rear window? You have great taste in cars! The work on the coupe is going to make it a great car when you are done with it.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-16-17 05:28 PM - Post#2714700
In response to junky
Yes sir, the 4 door is mainly for collision damage down the road. Just trying to protect this investment. I heard same age metal bonds better than replacement. I'm not a welder but it sounded interesting. Thanks for you feedback.
As far as the Cadillac goes, I'll need to clear it with a moderator first before posting. To answer you question, it's a single sheet of glass. No dividers.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-16-17 05:29 PM - Post#2714701
Edited by Spas602 on 11-16-17 05:36 PM. Reason for edit: No reason given.
62chevy427
Loc: laurens sc
Reg: 04-13-06
11-16-17 08:23 PM - Post#2714716
i restored one for a customer about 3 years ago. lots of work. you are doing a good job
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-17-17 03:27 AM - Post#2714743
In response to 62chevy427
Thanks for your feedback. I appreciate it.
Edited by Spas602 on 10-17-18 04:51 AM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-18-17 04:15 PM - Post#2714886
Edited by Spas602 on 11-18-17 04:18 PM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-18-17 04:18 PM - Post#2714887
Sorry, photos are being uploaded upside down.
Edited by Spas602 on 11-18-17 04:30 PM. Reason for edit: No reason given.
ARKAR
Loc: Arkansas
Reg: 01-26-09
11-18-17 05:02 PM - Post#2714889
Lord have mercy, looking good! Keep posting the pictures. Nice work and this is starting to make me want to get back on my '64. Took several years off to build a '53 pickup rat rod but my '64 is still sitting in my garage after I put floor pans in it.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
11-25-17 03:23 PM - Post#2715708
Edited by Spas602 on 11-25-17 03:31 PM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
12-01-17 04:41 AM - Post#2716506
Edited by Spas602 on 01-24-19 04:49 AM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
12-01-17 06:04 PM - Post#2716595
Edited by Spas602 on 10-17-18 04:53 AM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
12-03-17 07:57 AM - Post#2716727
Edited by Spas602 on 01-24-19 05:04 AM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
12-08-17 09:30 AM - Post#2717312
Edited by Spas602 on 01-24-19 05:10 AM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
12-09-17 04:15 PM - Post#2717439
Happy holidays everyone.
Edited by Spas602 on 12-09-17 04:18 PM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
12-14-17 06:57 PM - Post#2717973
More info on the 348:
.070 bore over
Unknown cam
4 speed engine
Ran when pulled.(seller didn't like the hp)
1959 Tri power setup.
Hei distributor
1958 generator
Edited by Spas602 on 12-15-17 03:37 AM. Reason for edit: No reason given.
DonSSDD
Reg: 08-21-01
12-15-17 04:54 AM - Post#2718002
One warning on the distributor, it looks like MSD? Some of them do not run good at all when brand new, quality issues.
Have you run the motor at all?
The tripowers can be finicky, unless built by a proven tripower expert. Issues with vacuum leaks until you get them set up right, then they can run great.
If you have issues with the motor running right when you first start it, you could be having tripower issues or distributor issues. I'm just suggesting you be prepared.
What was the HP issue the prior 348 owner had- too much or not enough?
Member #2194
DonSSDD
Reg: 08-21-01
12-15-17 05:58 PM - Post#2718064
If you block off the 2 end carbs for testing, you can get the motor running good, then move on to the 2 other carbs. The tri powers can be made to work very good if you get them set up correctly and a lot of people run progressive linkage. Basically the 2 end carbs should work like a 4 barrel, only open and used when you floor it.
I'd suggest you start a separate post looking for help with the tri power setup, maybe on the 58-60 forum, since they were used in those years and 61 only. You can also search on 348-409, lots of info on tri powers there.
Member #2194
DonSSDD
Reg: 08-21-01
12-15-17 05:59 PM - Post#2718065
Oh and Show Cars has lots of good parts for tri power carbs.
Member #2194
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
01-07-18 08:42 AM - Post#2720322
Thanks don. I found I needed a coil with this electronic distributor. Some have been telling me I may need to run a 60' degree on the spark plugs as well.
Edited by Spas602 on 01-24-19 07:01 AM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
01-25-18 03:26 AM - Post#2722052
Edited by Spas602 on 01-24-19 07:07 AM. Reason for edit: No reason given.
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
01-26-18 04:51 AM - Post#2722166
Edited by Spas602 on 01-26-18 04:52 AM. Reason for edit: No reason given.
