Username Post: 68 Camaro with CE block        (Topic#348005)
vu_doo2
Loc: Brisbane, Australia
Reg: 11-02-17
11-02-17 01:39 AM - Post#2713028
Hey Guys - appreciate any help on this topic. My Camaro has a CE block engine in it - CE068842. Any idea with out tearing the engine down what disp it might be please. It has 4 bolt mains and iron heads - Casting number 336781 is all I know. Many thanks in advance
models916
Loc: Addison, IL
Reg: 05-28-10
11-03-17 05:12 AM - Post#2713139
    In response to vu_doo2
The 4 bolt main block was in 69. More than likely a 350.
elcamino
elcamino
Reg: 03-30-00
11-16-17 07:57 PM - Post#2714708
CE068842
CE - Chevrolet Engine
0 - Year of Manufacture
68842 - Unit serial number (Note-Range 50000-79999 used by Tonawanda Engine Plant) If more were made they used a letter suffix, e.g. A68842, B68842 etc.
The "CE" coding was invented circa 1968 for short blocks that were replacements under the 5/50 Powertrain Warranty program that was in effect from 1967-1970. When the liability for replacement of 5/50 warranty engines expired in 1975, I'm sure there were a lot of "CE" short blocks in inventory, and those went into the parts system as out-of-warranty and over-the-counter short blocks. "CE" blocks were only available as short blocks (block, crank, rods, pistons) or as "fitted blocks" (block with ringed pistons fitted, no crank or rods). Good parts from the damaged engine were reused. The short block were approved generic replacements and nothing can be determined from the unit serial number what exactly was installed. The dealer went to the parts book and ordered what Chevrolet said was the correct replacement part for that engine option.
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
2016 Polaris RZR 900 EPS
pdq67
Loc: Columbia, MO, USA
Reg: 08-31-02
02-16-18 01:47 PM - Post#2724614
It can be a 302" with a 3" crank, a 327" with a 3.25" crank and a 350" with a 3.48" crank so go from there.
And somewhere along its life, it might have been bored so the only way to really know is to pull a head and measure its B&S, then you will know for sure.
pdq67
Execution time: 0.253 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:49 PM
