Username Post: 77 Vette questions        (Topic#347390)
KaelFarmer
KaelFarmer
Loc: Eau Claire, WI
09-28-17 10:11 AM - Post#2709120
Last night I acquired a 77 Vette coupe with T-Tops. This car does not appear to have seatbelts. Are they only lap belts or is this car simply missing them?
Also, I did not see a way to reset the trip odometer. How would I do this?
I am sure that I will come up with a lot more questions over time.
Thanks,
Kael
TAT_2
"18th Year" Silver Supporting Member, and Official CT Grim Reaper
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
09-28-17 04:40 PM - Post#2709146
    In response to KaelFarmer
THATS ONLY 2 QUESTIONS !!!
TRIP IS A PUSH BUTTON WHERE THE SPEDO IS.
IT SHOULD HAVE SHOULDER BELTS,TOP MOUNTING WHERE YOUR HEAD IS TO THE LEFT THERE SHOULD BE A HOLE IF REMOVED FOR SOME REASON.
CONGRATS
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
KaelFarmer
KaelFarmer
Loc: Eau Claire, WI
09-28-17 04:55 PM - Post#2709149
    In response to TAT_2
I see a bolt where the should belts should mount, but no belts. I got it from the original owner so I should be able to get clarification of a few things that may seem odd. Right now, I'm going to learn more about it as I drive it.
Kael
KaelFarmer
KaelFarmer
Loc: Eau Claire, WI
09-28-17 05:05 PM - Post#2709150
Kael
KaelFarmer
KaelFarmer
Loc: Eau Claire, WI
10-01-17 08:12 AM - Post#2709366
I spoke with the previous owner about the seatbelts. Apparently they were removed within the first 100 miles of the life of the car.
Now for my next question. Were the door mirrors corvette specific or did other GM cars use the same ones? I would like to add a mirror to the passenger side.
Thanks,
Kael
wagonmaster
wagonmaster
Loc: Loganville, Ga.
Reg: 04-28-00
10-06-17 06:10 AM - Post#2709909
Mirror for the right side should be available from our advertisers. Dealer may be able to order them as well...
Good luck with your new ride!
Hey T @!
Joe
KaelFarmer
KaelFarmer
Loc: Eau Claire, WI
10-06-17 03:28 PM - Post#2709955
    In response to wagonmaster
I was able to locate a mirror. Now the next part of the search is improved headlights without cutting the headlight buckets.
Kael
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
10-07-17 09:18 AM - Post#2710036
Any stock size replacement headlight will fit. There should be no reason to do any cutting to the headlight buckets.
Ken
36, 38 & 39 2dr sedan, 41 coupe, 54 convertible, 56 Nomad, 57 210 2dr sdn, 70 Camaro RS, Corvettes; 57, 61, 65 396 coupe, 67 427 convert, 72 T-top, 88 coupe,91 ZR-1, 07 Z06, 16 Z06, 07 Silverado, 09 BMW 135i vert.
http://www.picturetrail.com/ken
KaelFarmer
KaelFarmer
Loc: Eau Claire, WI
10-07-17 09:37 PM - Post#2710105
    In response to bowtiefan
I found some Sylvania Xtravision bulbs that are the correct size. I was also looking at some newer ones with replacable h4 bulbs. Those all appear to require cutting the headlight bucket. I also considered LED bulbs but I was having difficulty finding any that were legal for road use and able to use as separate high and low beams. The 7" bulbs on my other vehicles are much easier to find upgrades for. The 5-3/4" size doesn't seem to have much market support which is odd since they were used for MANY years.
Kael
Execution time: 0.117 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:41 AM
