Username Post: 200cid v6        (Topic#347049)
chucksue
Loc: Center all illinois
Reg: 04-10-17
09-08-17 02:29 PM - Post#2707064
I just found a 200 cid v6. The block casting number is 461344. It was made in 1978 and 1979. Where can I find a complete rebuild kit pistons and all? I need a distributor also.
wch
Loc: TX
Reg: 05-13-17
09-09-18 08:23 AM - Post#2745713
    In response to chucksue
that will be hard to find. just get a good running 4.3 out of something. a 4.3 with a 100k on the clock will go another 100K miles without touching it.
I only say that because 4.3's are easy to find. the early v6 stuff is tough to find
Casey
1966 Impala,2dr,283,PG,Wilwood brakes
1985 Chevrolet,C20,350,th400
1986 Chevrolet, Corvette,400ci Dart SHP,TH350
Edited by wch on 09-09-18 08:27 AM. Reason for edit: No reason given.
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
09-10-18 07:07 AM - Post#2745793
200 or 229 for that matter are not worth building IMO. A 4.3 Vortec is a MUCH better engine. It has the same external dimensions and makes 2x the power with better fuel efficiency. Thanks to the marine use you can get a cast iron or aluminum Vortec 4bbl intake and use a small 500 cfm Edelbrock or Q-Jet and make ~230 HP from a stock Vortec engine. I would use the hottest factory roller cam out of a 1993-1994 Vin W CPI engine. The Vortec 4.3 also has revised firing angles and a balance shaft and will run ALOT smoother than an odd fire 200.
Edited by 1983G20Van on 09-10-18 07:07 AM. Reason for edit: No reason given.
Mercedes
Reg: 07-09-18
09-13-18 01:52 PM - Post#2746064
    In response to 1983G20Van
If you check with Northern Auto Parts, you can buy nearly any engine kit from them. The parts on that engine are shared with other Chevrolet engines.
Execution time: 0.158 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:53 AM
