Username Post: 350HP/327 carb ?        (Topic#346277)
rod
Member #248 Senior Member
Loc: kingman,az
Reg: 04-29-00
07-29-17 03:06 PM - Post#2701959
I have an original 350 HP Holley carb. main body. I have lots of Holley parts, so I can build a complete carb. if I can get a few answers.
was this a 4150 [rear jet block] or a 4160 [rear jet plate] type? was the front float bowl inlet angled down or was it a banjo fitting [like most 1850 600s]? was this carb. rated at 585 CFM or 600 CFM?
thanks Rod in AZ
Member #409
07-29-17 07:29 PM - Post#2701992
    In response to rod
Do you have the carb list number? I have a Holley reference chart that shows original jetting, metering plates, etc.
"16th Year" Platinum Supporting Member & Senior Moderator
12-10-17 10:10 PM - Post#2717535
    In response to rod
The list number is 3245. They were listed at 600 cfm but apparently 585 cfm. It's very similar to the 2818-1 used on the Corvette 327/365 horse unit.
I know this is a dead post, but wanted to fill in for anyone's curiosity.
Execution time: 0.214 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:53 PM
