Username Post: 1972 A/C equipped Z-28s        (Topic#346113)
wagonmaster
wagonmaster
Loc: Loganville, Ga.
Reg: 04-28-00
07-20-17 07:54 AM - Post#2700704
I usually ask this about once a year or so, but it's been way longer this time around.
Anyone here have one of the very rare factory A/C equipped 1972 Z/28s??
They made 286 '72 Corvettes with A/C equipped LT-1s. not sure they made that many Z/28s... Have seen no documented number.....Anyone??
Hey T @!
Joe
models916
Loc: Addison, IL
Reg: 05-28-10
07-25-17 05:21 AM - Post#2701337
    In response to wagonmaster
Friend of mine bought one new. Was auto and air. GM allowed this because the z motor was hydraulic lifter.
wagonmaster
wagonmaster
Reg: 04-28-00
07-26-17 02:28 PM - Post#2701560
    In response to models916
"GM allowed this because the z motor was hydraulic lifter."
Actually the 1972 models were the last of the solid lifter 350 LT-1s. The 1973 units were hydraulic, the hi-po unit being the L-82.. If he had hydraulics it wasn't a 1972. You could get a turbo 400 auto with the Z-28 for the first time in '72....
Hey T @!
Joe
Ray1999Z71
Ray1999Z71
Loc: Taylorsville KY
Reg: 04-11-17
10-18-17 08:13 AM - Post#2711249
Not a Z-28, but my base 72' has air....why do you ask about this? You looking to buy a Z with air? I'd just add a Vintage AC unit to a Z and call it done.
Dad always said "It'll be aight!"
Edited by Ray1999Z71 on 10-18-17 08:13 AM. Reason for edit: No reason given.
wagonmaster
wagonmaster
Reg: 04-28-00
10-18-17 05:37 PM - Post#2711298
    In response to Ray1999Z71
No, I ask this question every year or so. The 1972 Z-28 had, near the end of the model year, an approved option for A/C. Solid lifter high performance engines had not had this since 1965. I am talking about a factory A/C equipped Z-28. They are very rare. Same with Corvettes with the LT1 engine in 1972, but I have seen several of these and sold one, new in 1972.
Thanks for your response.
Hey T @!
Joe
"15th Year" Platinum Supporting Member & Moderator
10-18-17 09:30 PM - Post#2711327
Hey Joe, did those compressors use a larger diameter pulley to slow down the action or were they a different design?
wagonmaster
wagonmaster
Reg: 04-28-00
10-23-17 11:59 AM - Post#2711839
    In response to 427SS65
It's been a while since I've seen one, but my recollection is that they were the very same as the regular 350/4 bbl. The 1972s were very low compression and even with solid lifters they weren't exactly killers from the factory....
Hey T @!
Joe
elcamino
elcamino
Reg: 03-30-00
10-29-17 04:58 PM - Post#2712615
Reason for no A/C on solid lifter engines: Solid lifter engines turn high RPM’s. The A/C compressor and condenser cannot handle the high rpm’s.
2018 Polaris RZR S 900 EPS
10-29-17 10:38 PM - Post#2712657
    In response to elcamino
NYH1
Loc: Central New York
Reg: 07-15-09
08-07-18 07:09 PM - Post#2742292
The TH400 was available in the Z-28 from '70 to '74.
NYH1.
'78 Camaro, mild Vortec head 385 stroker, 9.1 comp. Lunati Voodoo 262/268 hyd. ft. cam, RPM Intake, 650 AVS carb, TH350 Coan 11" 2600 stall, 8.5" 10 bolt. 3:42 posi, 1 5/8" Full length Headers, 2 1/2" Flowmaster Exhaust System.
Mercedes
Reg: 07-09-18
08-11-18 01:29 PM - Post#2742746
    In response to NYH1
I have been told that by 72, all of that was gone and you could get AC on any engine.
wagonmaster
wagonmaster
Reg: 04-28-00
08-18-18 06:16 AM - Post#2743480
    In response to Mercedes
The turbo 400 statement is correct. but the a/c equipped LT-1 engines were very late 1972 production options in the Corvette and Z-28. Not available all year.
Hey T @!
Joe
NYH1
Reg: 07-15-09
08-19-18 03:16 PM - Post#2743631
How times have changed. Now every car comes pretty much standard with A/C. Camaro's, Challenger's, Mustang's, Corvette's ect. no matter how they're setup. Having A/C is nice though for sure.
NYH1.
Mercedes
Reg: 07-09-18
08-20-18 12:52 AM - Post#2743685
    In response to NYH1
I did a study in college and showed production of cars equipped with AC.
You could see the sharp rise in AC equipped cars starting with the 1973 model year. From there, it increased almost exponentially.
This phenomenon pretty much goes along with the old saying that once you have it you can't live without it.
Today's engines have revving capability beyond that of years ago. The computer turns off the AC if needed based upon speed.
NYH1
Reg: 07-15-09
08-20-18 11:08 AM - Post#2743765
Some good points there for sure.
The new Dodge Demon (Challenger) incorporates the A/C system into the intercooler system for the supercharger. I don't know all the details on how the system works.
NYH1.
Mercedes
Reg: 07-09-18
08-20-18 01:16 PM - Post#2743780
    In response to NYH1
I'll have to look into the Dodge Demon AC system. I wonder if they are piggy backing the AC condenser with the intercooler so that both are able to lose heat more efficiently?
I'm certified in auto AC so I've studied the systems over the years.
The early systems ran the compressor full time and returned any excess refrigerant to the suction line if not needed in the evaporator. The problem with that is that you have the compressor running at full capacity every time the system is on regardless of cooling demand.
The next generation of system cycled the compressor based upon the suction line pressure. You basically built up enough refrigerant in the pressure line and when the suction pressure would reach around 20 lbs/in, you kill the compressor electrically for a while until the pressure builds up to around 45 lbs/in. Then, you re-engage the compressor and so on. That method of controlling the refrigeration circuit went largely unchanged for about 25 years.
Now we have variable capacity compressors which are electronically controlled by a solenoid valve. The system is always running although very little refrigerant is moving when it is off. This greatly reduces the amount of drag on the engine as the interior of the car reaches temperature and makes the AC system very efficient to virtually no impact on power and fuel economy. These systems are also electronically controlled for temperature and do a great job.
Things have really changed!
NYH1
Reg: 07-15-09
08-20-18 06:24 PM - Post#2743824
Well at least you have a clear understanding on how A/C systems work. Me on the other hand....I know how to turn them on and off!
It was a while ago that I heard about the Demon's system. IIRC, the cool/cold refrigerant may be cycled either through the supercharger or the intake. Then ran back through the A/C system to cool it back down normally.
I think you have to choose which system you want on. Either your regular A/C system or the intercooling system.
It'll be interesting to see what you find out.
NYH1.
NYH1
Reg: 07-15-09
08-20-18 06:25 PM - Post#2743825
    In response to NYH1
wagonmaster, did you ever find a car?
NYH1.
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
08-21-18 10:12 AM - Post#2743893
    In response to NYH1
NYH1.
The intercoolers are actually cooled by a mixture of antifreeze and water. The intercooler water loop is chilled by a/c refrigerant in a water cooler. The Mustang Cobra guys have been messing with them for years.
https://killerchiller.com/
Mercedes
Reg: 07-09-18
08-21-18 11:23 AM - Post#2743899
    In response to 1983G20Van
That sounds like a very interesting system. I'll have to check the web sites to see the particulars of that.
I know that the late 80s and early 90s Mercedes vehicles used the suction (cold) line on the air conditioning system to cool the fuel prior to it entering the master distribution box. Unfortunately, if it leaked fuel, you had to either bypass the hose or replace it.
NYH1
Reg: 07-15-09
08-21-18 02:18 PM - Post#2743913
I knew they used the A/C system somehow. Wasn't sure exactly how.
NYH1.
Mercedes
Reg: 07-09-18
08-22-18 09:36 AM - Post#2743997
    In response to NYH1
I looked at the link. It appears that they are using the suction line (which is cold) to cool down the coolant, which is a good idea.
wagonmaster
wagonmaster
Reg: 04-28-00
08-25-18 03:58 AM - Post#2744312
    In response to NYH1
Haven't yet. I was really just checking to see if any one of our crew owned one.... Didn't make many....
Hey T @!
Joe
wagonmaster
wagonmaster
Reg: 04-28-00
10-16-19 01:54 PM - Post#2778054
Bump...
Hey T @!
Joe
Execution time: 0.163 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:35 AM
