Username Post: 76 Camaro break light suggestions        (Topic#345830)
rdobbs
Loc: Springfield, Tn 37172
Reg: 07-13-09
07-05-17 08:39 AM - Post#2698814
Bought car about 3 yrs ago. Appears the previous
owner did some tinkering with wiring. Passenger
side brake light works, but drivers side does not.
Changed bulb and checked for power but have none.
Could a person tap into the passenger side brake
and run wires to drivers side? Any other suggestions would be appreciated.
DECEASED
07-05-17 11:49 AM - Post#2698844
    In response to rdobbs
  • rdobbs Said:
.....Could a person tap into the passenger side brake and run wires to drivers side? Any other suggestions would be appreciated.
Do your brake lights and rear turn signals share the same bulbs? If no, go ahead and run a jumper like you asked about. If yes, does your driver side rear turn signal work normally?
rdobbs
Reg: 07-13-09
07-05-17 12:37 PM - Post#2698845
Thanks Raycow. Brake has its own separate bulb.
Execution time: 0.121 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:03 PM
