Username Post: Piston to valve clearance        (Topic#344526)
Chevelless70
Loc: Somerset MA
Reg: 03-23-17
05-05-17 05:25 PM - Post#2689748
Does it matter which cylinder you check for piston to valve clearance? I measured #2.
Thx
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
05-05-17 06:04 PM - Post#2689751
    In response to Chevelless70
if you have a minimum of .120 on both the intake and exhaust valve on that #1 and #2 cylinder (one on each bank) I think youll be ok, measuring just that cylinder , if either the intake or exhaust valve has less than .100 ID measure all the cylinders just to be sure!
don,t forget to verify the valve edge to valve pocket clearance along with the valve face too piston deck clearances
Chevelless70
Loc: Somerset MA
Reg: 03-23-17
05-05-17 06:31 PM - Post#2689756
    In response to grumpyvette
#2 cylinder measured
Intake .290
Exhaust .300
Is that too much clearance?
Measured with .039 compressed gasket.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
05-05-17 06:47 PM - Post#2689757
thats PLENTY of clearance if you got that with the valves properly adjusted while rotated the engine a full 720 degrees and measure the distance the open valve and pistons
you obviously have a reasonably low compression and mild cam
Chevelless70
Loc: Somerset MA
Reg: 03-23-17
05-05-17 06:52 PM - Post#2689758
Compression is 9.7
Cam edlebrock 560/573
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
05-07-17 10:35 AM - Post#2690046
http://www.cranecams.com/product/cart.php?m=produc...
http://www.cranecams.com/userfiles/PP0811A_Sin gleP...
that sounds like your using a cam similar to an early l88 style cam, which was designed to run in a 10.5-11:1 compression engine
Edited by grumpyvette on 05-07-17 10:36 AM. Reason for edit: No reason given.
Execution time: 0.238 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:59 PM
