 Page 2 of 2 <12
Username Post: Gauge cluster w/ tach        (Topic#344308)
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
05-02-17 02:29 PM - Post#2689335
    In response to socalarch
  • socalarch Said:
Is there a definitive way of telling the difference between the two?
Will a '91 cluster function in a '93 truck?
There is a picture of the back of an 88-91 here. https://www.chevytalk.org/fusionbb/showtopic.php?ti... If you have a 92-94 it won't look anything like that. I will say a 91 won't function in a 93. Anything is possible, but it would take major rewiring.
Jeff
socalarch
socalarch
Loc: So. Bay L.A.
Reg: 09-13-10
05-02-17 03:04 PM - Post#2689341
    In response to bowtie44s
Therefore, based on my photos posted earlier in this thread, my tach unit is an '92 or later.
What is the proper method of testing the white wire at the plug connector with a meter? With the truck running, what should the signal current measure?
I carved this cluster connector mounting point out of a '95 truck on my trip to the wrecking yard today. The intent is to rivet or glue this piece into place to the '88-'91 dash.
The additional parts plus the carpet for the back wall of the cab ran me a whopping $3.
Attachment: Photo0219.jpg (546.98 KB) 13 View(s)
Gary
1993 GMC Sierra 2500
1964 Buick Electra 225
Edited by socalarch on 05-02-17 03:08 PM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-02-17 05:09 PM - Post#2689355
Simple answer is NO.
Not easily anyway.
I am going to go on a assumption here and say you bought the dash and the cluster out of 2 separate trucks. Am I right?
Please post a picture of the plug on your truck so it can be determined if it has a tach wire on it.
Also note that there is a v6 cluster and a v8 cluster. Will get into that more if you can get it at least functioning.
Also a 88-91 cluster plug is nothing like a 92-94, therefore I do not think you have a 91 cluster
Old School GM fan FOREVER
Edited by rockfangd on 05-02-17 05:13 PM. Reason for edit: No reason given.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
05-02-17 05:24 PM - Post#2689357
    In response to rockfangd
Here's his pic. It has the tach lead.
Attachment: med_1493588884-Photo0215.jpg (106.5 KB) 15 View(s)
Greg
'00 Explorer XLT 4.0 V6 Auto
socalarch
socalarch
Loc: So. Bay L.A.
Reg: 09-13-10
05-02-17 06:51 PM - Post#2689368
Not easily anyway.
I am going to go on a assumption here and say you bought the dash and the cluster out of 2 separate trucks. Am I right? Yes, you are correct.
Also note that there is a v6 cluster and a v8 cluster. Will get into that more if you can get it at least functioning. Already posted above. The point is that there is a white wire in my existing cluster and the cluster I salvaged with the tach; they are identical. which is why it makes sense to me that there should be a current/signal coming across the white wire into the cluster and it should be detectable with an ohm meter. The question is what should that current be (millivolts, volts) and would one simply probe the red meter lead to the wire and put the black to ground?
Also a 88-91 cluster plug is nothing like a 92-94, therefore I do not think you have a 91 cluster. I think we are over the 88-91 cluster issue. Everything is 92-94.
Gary
Edited by socalarch on 05-02-17 06:55 PM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-02-17 07:06 PM - Post#2689370
hmm.
The tach signal is a negative signal that is pulsed.
If it were me I would ohm the wire in the plug to the the spade under the hood. It should have 0 ohms.
I would recommend it with the battery disconnected.
Let me see if I can get the exact pin.
Edit. I think someone mentioned it was pin 7.
Look at the diagram I posted. Says it is Pin T. WHITE
Also look at the left side of the diagram as it mentions the splice I was referring to that joins the cluster feed, test spade, and coil feed together
Attachment: 94_cluster.pdf (68.56 KB) 24 View(s)
Edited by rockfangd on 05-02-17 07:19 PM. Reason for edit: No reason given.
socalarch
socalarch
Loc: So. Bay L.A.
Reg: 09-13-10
05-02-17 09:14 PM - Post#2689387
  • rockfangd Said:
hmm.
If it were me I would ohm the wire in the plug to the spade under the hood. It should have 0 ohms.
I would recommend it with the battery disconnected.This will show continuity, but is there a way to probe the white wire at the plug while the truck is running to confirm the pulse is being sent? With the plug not plugged into the cluster, positive probe to white wire, negative probe to ground, what would/should the pulse current be (millivolts, volts)? If the current is present at the wire but the tach does not move, then it would be an internal cluster issue of some sort- yes?
Also look at the left side of the diagram as it mentions the splice I was referring to that joins the cluster feed, test spade, and coil feed togetherReads just like the diagram I posted on 4/30.
Gary
Senior Moderator
05-03-17 08:29 AM - Post#2689424
This one really went off the rails and I couldn't follow every response.
My best guess is an unlikely one historically, but makes most sense in this case. I think the tach cluster you got is probably defective. If you have the opportunity to try another, I would.
socalarch
socalarch
Loc: So. Bay L.A.
Reg: 09-13-10
05-03-17 11:57 AM - Post#2689453
    In response to someotherguy
Richard, maybe it's just your words of intimidation- the tach is functioning now (but the brake and information lights are on... I'll think about that later.
I have no clue as to why the first three times I plugged the unit in it wasn't working.
But I have answered some of my questions from above.
I followed ChevyTech's and Rockfangd's lead- I tested the white wire from the plug to connection C200 to the spade for continuity and resistance. All checked out fine.
I then followed my own query- started the truck and tested voltage from spade to ground- 11-12 volts. Then tested the white wire at the plug, T to Q/N on the connector- 11-12 volts.
Then plugged the unit in, started the truck and, voila.
Gary
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-03-17 06:10 PM - Post#2689498
cool.
It almost sounds like you are not getting a good connection to the plug at the cluster itself.
Did you try expanding the pins a little?
They press against the printed board, and if bent or worn slightly may not make good contact.
Austmurr89
Reg: 09-18-17
09-18-17 08:49 AM - Post#2708005
You say u are familiar w the 88 to 90 moonie correct... I have an 89 and no speedometer reading I changed the sensor and nothing...
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
09-18-17 04:28 PM - Post#2708050
    In response to Austmurr89
It took me a while to figure it out but if you read this it will walk you through how to test it. https://www.chevytalk.org/fusionbb/showtopic.php?ti...
Jeff
B.eriic
Reg: 01-31-20
02-01-20 12:00 AM - Post#2785583
Anybody know where I can buy this harness connector?
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
02-01-20 10:18 PM - Post#2785656
    In response to B.eriic
You won't find it new. You'll have to go to a junk yard.
Jeff
 Page 2 of 2 <12
Execution time: 0.226 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:44 PM
