Username Post: Fuel gauge not working        (Topic#344213)
Bowtie_Guy
Bowtie_Guy
Loc: Ohio in the "rust belt"
Reg: 09-04-04
04-22-17 11:34 AM - Post#2687744
We're having a typical issue with the fuel gauge not working on a 72' Nova without a wiring diagram yet. We've tried cleaning up the ground wire to the body for the sending unit under the body as it disintegrated when moving it around, but the fuel gauge still reads full over. Took a tester to the brown wire in the trunk and got the gauge to move downward, but not sure which direction to go for a faulty connection now. Any opinions on where to go next? I am thinking that ground wire goes to the sending unit in the fuel tank, but before we start yanking the gas tank out I thought I'd ask you all here for help. Thanks....
67' Chevelle SS California car needs much
97' K1500 4X4
72' Nova 350 A/C car (survivor garage kept)
2012 Silverado 4X4 LTZ
62sedan
Loc: Above the red Texas dirt
Reg: 08-12-02
04-22-17 04:11 PM - Post#2687793
    In response to Bowtie_Guy
Brian,
If you don't get any answers on this site (as this forum is kind of slow in participation), you might want to post your question(s) here >>>>> http://www.stevesnovasite.com/forums/
Just a suggestion, as I have no personal affiliation with Steve's Nova Site.
Chuck
Bowtie_Guy
Bowtie_Guy
Reg: 09-04-04
04-22-17 05:03 PM - Post#2687800
    In response to 62sedan
Thank you, it's all good. I found my schematic in a manual and I guess my son and I will be dropping the gas tank. I wasn't sure if there was another path the juice might be going (or not going) but it seems the circuit is simply through that sending unit and its not doing its thing. But I'll check out that other site just in case.
97' K1500 4X4
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
05-01-17 02:39 PM - Post#2689182
Personal experience there is just the one wire that goes to the top of the tank to the sending unit, then the ground wire that comes off the unit and bolts to the body by the bumper. If the wire broke at the unit on the ground, that'd be a problem. It's also just a weak slip connection plug on the unit, so that could have come loose or have corrosion in it. Most likely cause though, I'd say is probably the sending unit. (P.S. after dropping more of these tanks than I care to admit, take the ground wire off first, and have a spare nut and bolt with washers ready for when the speed nut on the tank straps break, because they probably will)
"8 cylinders of why the f&@% not" - me
Execution time: 0.404 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:05 PM
