Username Post: How to measure piston to deck/dome pistons        (Topic#344028)
Chevelless70
Loc: Somerset MA
Reg: 03-23-17
04-14-17 02:50 PM - Post#2686634
BBC 402 with dome pistons. How do I measure piston to deck?
04-14-17 06:18 PM - Post#2686663
    In response to Chevelless70
Run the piston up to tdc, use a depth mike to measure from the deck to the flat area of the piston, not at the domed portion.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
04-15-17 04:13 AM - Post#2686703
Edited by grumpyvette on 04-15-17 05:41 AM. Reason for edit: No reason given.
Chevelless70
Loc: Somerset MA
Reg: 03-23-17
04-30-17 03:54 PM - Post#2689033
[image]http://[/image]
Thank you!!
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
04-30-17 04:35 PM - Post#2689041
glad to help where I can
Execution time: 0.142 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:08 AM
