55randy53
Reg: 05-22-11
04-10-17 06:51 PM - Post#2685943
is the throttle pass through on the firewall the same on the chevells, as on the chevyII's? my 65 chevyII has a lokar, which i don't like, so going back to the original pass through. i got the pass through as a swap meet. looking at the firewall from engine side, the upper bolt hole is on the right and the lower hole is on the left. on the pass through that i have, the holes are swapped. i would just drill new holes but the lower hole on the right, the part i have,would fall in bend in the firewall. need help Randy
