Username Post: pass through        (Topic#343936)
55randy53
Reg: 05-22-11
04-10-17 06:51 PM - Post#2685943
is the throttle pass through on the firewall the same on the chevells, as on the chevyII's? my 65 chevyII has a lokar, which i don't like, so going back to the original pass through. i got the pass through as a swap meet. looking at the firewall from engine side, the upper bolt hole is on the right and the lower hole is on the left. on the pass through that i have, the holes are swapped. i would just drill new holes but the lower hole on the right, the part i have,would fall in bend in the firewall. need help Randy
62sedan
62sedan
Loc: Above the red Texas dirt
Reg: 08-12-02
04-11-17 04:58 AM - Post#2685973
    In response to 55randy53
As this forum does not get a lot of audience, you may want to join and post your questions over at http://www.stevesnovasite.com .
Sorry that I can't help with your immediate situation, but maybe the referred link will help you. Good luck.
Chuck
Execution time: 0.095 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:12 AM
