Username Post: DOES A NEW CLUTCH HAVE TO BE DIALED IN WITH AN INDICATOR?        (Topic#343664)
1980 MALIBU 406 CU. IN.
Reg: 03-26-17
03-29-17 05:29 PM - Post#2684092
I have a small vibration in my floor shifter at higher Rpm's.
DOES THE CLUTCH HAVE TO BE DIALED IN WITH A DIAL INDICATER WHEN INSTALLED WITH THE BOLTS STILL LOOSE?
THERE DOES NOT SEEM TO BE MUCH PLAY IF ANY IN THE BOLT HOLES WHEN ALL 6 BOLTS ARE IN PLACE, AND IS THERE A GOOD PLACE TO SET THE DIAL INDICATOR POINTER ON THE CENTER FORCE DUAL FRICTION PRESSURE PLATE WHILE DOING THIS?
EVERYTHING IN MY MALIBU IS NEW OR REBUILT INCLUDING A NEW DRIVESHAFT (SPUN BALANCED AT HIGH RPM, TWICE!)AND THE MUCCI M22 ROCK CRUSHER TRANY HAD ALL NEW BEARINGS AND SEALS INSTALLED SO IT NOW LEADS ME TO THE CLUTCH/DISC/FLYWHEEL ASSEMBLY.
DECEASED
03-31-17 08:25 PM - Post#2684439
    In response to 1980 MALIBU 406 CU. IN.
I have never heard of a pressure plate needing to be dialed in. Sometimes a bellhousing needs to be dialed in, but that's a whole different story.
Execution time: 0.119 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:50 PM
