Username Post: 400 CU. IN. FLYWHEEL QUESTION        (Topic#343577)
1980 MALIBU 406 CU. IN.
Reg: 03-26-17
03-26-17 07:54 PM - Post#2683545
I have a 406 cu. in. small block chevy in my Malibu.
The motor was built with a 350 crank so I believe it is now an internally balanced motor?
The harmonic balancer is smooth on both sides with no weight or different size cut outs on it.
I have an aluminum Flywheel that was for the 400 cu. in. Externally balanced engine.
My question is, Can I remove the counter weight that is bolted on the back side of this flywheel with 2 bolts and use it on my internally balanced small block engines?
DECEASED
03-27-17 11:21 AM - Post#2683637
    In response to 1980 MALIBU 406 CU. IN.
I have asked the moderator to move your other identical thread from the 70-72 Chevelle forum to this forum.
Reg: 03-26-17
03-29-17 04:49 PM - Post#2684078
Thanks Ray,
Then can you answer my question?
Most Malibu's don't have a 406 cu.in. in them, that's why I posted in the 70's Chevelle forum.
DECEASED
03-31-17 08:22 PM - Post#2684438
Answered in your other thread with the same subject line.
Execution time: 0.165 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:43 PM
