Boosted54
![Boosted54](https://www.chevytalk.org/fusionbb/images/avatars/7.jpg)
Loc: Portland, Oregon
Reg: 11-28-14
03-26-17 10:53 AM - Post#2683426
I'm sure this question has been asked many times and I have done my homework searching the archives of this particular page but have found very little information.
I picked up a Silverado to do an LS engine/trans swap in my GMC. The donor is an actual driving vehicle. I'm contemplating just taking the entire rolling chassis and putting under the GMC. Who has done this and what challenges lie ahead for this type of swap? Pictures?? The donor is an 02 2wd.
454cid
Loc: West Michigan
Reg: 02-18-12
03-26-17 11:44 AM - Post#2683429
In response to Boosted54
From what I've read of body swaps, they are not easy, and often look odd, when finished. I don't see any reason to not use the original rolling chassis of your truck. Swapping in the newer drivetrain has been done many times, and aftermarket parts to help you do that are available.
Boosted54
Reg: 11-28-14
03-26-17 01:21 PM - Post#2683451
In response to 454cid
I have a complete front & rear suspension from a C4 Vette that I could graft onto the GMC OE frame but was hopefull the full rolling chassis would be faster swap & could utilize the 4 wheel disc, anti lock brakes, etc....
Well still undecided, anyone else have any info or pictures of a C10/late model Silverado swap?
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
03-29-17 04:28 PM - Post#2684072
I was going to help my brother with a similar swap a while back before he ended up selling the truck. I looked into it a little and did not find much info on this.
I agree with you as far as thinking it would be nice to have the newer style frame and suspension. The mounts for the engine can be swapped and all of that but at least if you could do a body swap with out too much effort it would be a nice time saver.
If you do it I would like to see pictures and details.
Boosted54
Reg: 11-28-14
03-30-17 08:55 AM - Post#2684171
In response to LUVmachine
Thanks for the input. Hopefully someone that has done one of these swaps will drop some info. Whatever direction I go i will post pics.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
09-22-17 05:55 AM - Post#2708487
I have nothing to do with this other than I have read the thread. The pictures do not work anymore because of photobucket.
Hope these help.
help.https://ls1tech.com/forums/conversions-hy brids/412057-my-68-ls1-sh ortstep.html
Another one:
https://www.performancetrucks.net/forums/projects-...
This thread does work with the pictures.
http://67-72chevytrucks.com/vboard/showthread.php?...
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse |
Boosted54
Reg: 11-28-14
09-24-17 10:10 AM - Post#2708685
In response to Andy4639
Nice, thank you.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
09-25-17 10:53 AM - Post#2708787
Welcome.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse |
Boosted54
Reg: 11-28-14
10-11-17 04:45 PM - Post#2710570
Well it looks like I may get going on this late Nov or early Dec. Seams to be pretty straight forward with the typical fab work required for most similar swaps. Plasma, Mig, & some time. Looking forward to this one.
Boosted54
Reg: 11-28-14
06-15-18 07:29 AM - Post#2737022
The gathering of parts has begun. Mock up motor for the single turbo set up is coming along. Headers & turbo coming soon.
Boosted54
Reg: 11-28-14
07-23-18 10:24 PM - Post#2740969
Gathering more parts before i get started. Going to try out the new Hooker turbo manifolds. Might be a tight fit but worth a try.
Boosted54
Reg: 11-28-14
12-05-18 10:29 PM - Post#2753569
2” dropped spindles for the 02 chassis are here.
Boosted54
Reg: 11-28-14
02-20-19 09:31 PM - Post#2760394
HYPR
![HYPR](https://www.chevytalk.org/fusionbb/fbbavatars/av-2005-1202005346.jpg)
Loc: Shaking and Burning!
Reg: 07-19-01
03-02-19 07:38 AM - Post#2761104
If that is an actual photo of the completed build then Wow that came out amazing. Do you have any more detailed photos of the build?
Bob
Boosted54
Reg: 11-28-14
03-02-19 10:38 AM - Post#2761118
In response to HYPR
It is an actual photo of the truck with the wheels & backdrop shotoshoped in. I will start posting up build pic soon as im still gathering parts & trying to wrap up other projects.
Boosted54
Reg: 11-28-14
03-04-19 08:59 PM - Post#2761330
Boosted54
Reg: 11-28-14
03-29-19 08:41 PM - Post#2763236
The Garrett turbo has arrived
Boosted54
Reg: 11-28-14
03-04-22 06:26 PM - Post#2837506
I guess its been a while since i posted on here. Got tied up with other projects.
Boosted54
Reg: 11-28-14
03-06-24 01:35 PM - Post#2867615
It’s been a while. It’s a driver now but lets get caught up.
A bit of a break down of the engine.
4.8 block .20 over
Eagle H Beam rods
Carrillo Bullet pistons
Polished crank
Balanced rods
ARP Head studs
Trick flow Gen X 205 heads w/titanium seats
Harland Sharp rockers
Comp Cams lifters
Comp Cams “purple unicorn” turbo cam
95lb injectors
Aluminum summit intake
90mm MSD tapered throttle body
Garrett GT4202R
50mm WG
50mm BOV
Aeromotive 450
OEM ZR1 MAP sensor
OEM 2010 Camaro MAF
4” exhaust
rcr3
Site Ambassador -"20th Year" Gold Supporting Member
![rcr3](https://www.chevytalk.org/fusionbb/images/avatars/2020-12-15_14-15-33.jpg)
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
03-07-24 08:20 AM - Post#2867636
Very nice!!
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'73 Nova pro-street project
'17 Chevy Trax LT
Boosted54
Reg: 11-28-14
04-24-24 08:58 PM - Post#2869158
In response to rcr3
Rolled into the first event of the year
rcr3
Reg: 11-24-02
04-25-24 06:58 AM - Post#2869168
Like
'67 Camaro survivor
'17 Chevy Trax LT
