 Page 3 of 4 « First<1234
Username Post: 1959 Biscayne "Da Biskit"        (Topic#343498)
TYTILIDIE
TYTILIDIE
Loc: Colorado Springs
Reg: 10-21-15
10-24-17 11:58 AM - Post#2711973
    In response to beagrizzly
Absolutely!!
Here is the link, I got the P4
http://www.tanksinc.com/index.cfm/page/ptype=produ...
I used this for a filter/regulator
Me
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
10-26-17 08:14 AM - Post#2712225
    In response to TYTILIDIE
Sweet! Thank you for the reply. I have a TIG welder, so installation shouldn't be a problem. This will solve a lot of problems for my installation.
YOU DA MAN!
Griff
if you're gonna be a bear.......................
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
12-13-17 07:13 PM - Post#2717856
She's coming together!! I got the front and rear windshields in, side mirrors installed, fender molding (spears), tail lights, trunk moldings, parking brake, brake lines, lowered the car, installed the gas pedal, radiator, and some other crap. Big things left are exhaust, a couple broken exhaust manifold bolts in the heads, interior, side glass and I will be pretty close to done!
Me
my60belair
my60belair
Loc: Ontario, Canada
Reg: 08-25-14
12-13-17 08:07 PM - Post#2717863
Your work is amazing. I can only hope I can get my car looking half as good as yours when I'm done. Great job and keep those pictures coming.
Can't wait to see it done
If at first you don't suceed, destroy all evidence you ever tried...
1960 Bel air Sport Coupe, 1964 Pontiac Catalina Convertible
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
12-15-17 05:24 AM - Post#2717997
    In response to my60belair
You've come a long way baby- looks great.
Member #2194
Chevyfan60
Chevyfan60
Loc: Longmont, CO
Reg: 04-19-01
12-15-17 11:44 AM - Post#2718028
Looks great, nice work!
Michael
1960 Impala 348, 1960 El Camino (x2), 1960 Nomad, 1992 S-10 Blazer, 2001 GMC Sierra 2500HD,
2002 Trailblazer
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
12-17-17 06:46 AM - Post#2718238
    In response to Chevyfan60
Thanks guys! I wasn't going to worry about things like the trunk emblem initially but for $60 for a brand new one it made sense. It makes a HUGE difference too. I also wish I would have known in the past how easy polishing is. I used to pay my guy $12 per foot (which is definitely worth at he does an amazing job) but when I took on this project I decided since there is so much to polish, I'd do it myself. Its actually really easy. Now I am paying pennies per foot.
Me
Edited by TYTILIDIE on 12-17-17 06:48 AM. Reason for edit: No reason given.
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
02-13-18 10:32 AM - Post#2724259
Got the tail lights working along with the front parking lights, hood latch and installing the grill screens. The brackets for the screens were so bad I had to make some out of some 16 gauge stainless. I even polished them up. They seem to fit well. Today I'll be installing the rest of the hood vent trim and then will prepare to pull the engine to fix a couple broken exhaust manifold bolts and swap the stock 5.3l pan to the Holley pan.
Me
Edited by TYTILIDIE on 02-13-18 10:33 AM. Reason for edit: No reason given.
DonSSDD
DonSSDD
Reg: 08-21-01
02-13-18 07:01 PM - Post#2724303
Nice work, getting more exciting.
Member #2194
ShortyLaVen
Loc: Minneapolis, MN, and Phoe...
Reg: 01-23-18
02-15-18 06:05 PM - Post#2724520
    In response to DonSSDD
Kool story and awesome pics!!
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
02-20-18 07:46 PM - Post#2725043
    In response to ShortyLaVen
Got the broken exhaust manifold bolts removed and repaired. I had to pull the motor to do it and pull the heads off. I decided to spruce it up a smidge before putting it back in. I was finally able to install the driver side header! Also installed the Holley oil pan.
Me
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
03-03-18 06:45 AM - Post#2726298
Been at it again trying to knock out my 90hr punch list. So, I got the engine back in the car, looks so much better
Then I went and got a gas pedal for a 90's pick Chevy truck (full size) and installed it with the throttle cable for the 04 Yukon I got the engine from. Biggest issue here is the way you have to mount it. It will require me heating up the pedal rod and bending it 2 different directions so pedal travel is correct. Not a big deal though.
Also, started gluing the windshield in. I installed both upper and lower windshield moldings s well. I'll post a pic of it all done with the side moldings later after I install them this afternoon.
I'd like to install the cowl panel, I am hoping I can find my bezels for the wipers because it doesn't look like you can buy them new.
Also, I fired up the engine!! It starts right up but dies immediately. I don't have the MAF or O2's hooked up yet so we'll see what the problem ends up being. I imagine it should still run on it's own. It's possible that the injectors need cleaning. I bought the engine 3 years ago and who knows how long it was since it had ran prior.
https://www.youtube.com/watch?v=Be6nHuwLUHc
Me
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
03-03-18 10:46 AM - Post#2726316
Don't know if they're the same, but I just replaced the wiper bezels on my 1960 Impala convertible, as the chrome was a bit worn. Found them on eBay quite cheaply - I still have the old ones if you are stuck, which are not in bad shape really.
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
03-04-18 03:24 PM - Post#2726421
    In response to Hugomiller
I luckily found mine but thanks!
Got the rest of the trim done today. along with the wipers, cowl panel and stated taping off the rear glass.
Me
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
03-05-18 08:57 AM - Post#2726492
LOOKING SWEET!!!!!
Griff
2005 Yukon XL
2009 Silverado
2011 Escalade ESV
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
03-06-18 06:43 AM - Post#2726622
Thanks Dood!!
Got the rear glass and trim done. My clips for the side glass molding were toast so I used upper windshield molding clips and modified them. It went quick but was definitely a PITA
I'm sure some people look at my moldings and think, why the hell would he put dented moldings on? I fixed what I could without having to sand but since this car will be a driver and I am able to polish it all I am not that worried about it. I am hoping that when I start driving the car it wont start eating at me. LOL
Me
Edited by TYTILIDIE on 03-06-18 06:46 AM. Reason for edit: No reason given.
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
03-15-18 07:39 PM - Post#2727775
Been working on the door glass channels. As I am sure everyone knows, no one sells them and it is rare they show up for sale anywhere. So naturally, I made some. I used a slightly thinner gauge metal but it is stainless. After flanging the sides, it is extremely rigid, no give at all. Hope I don't regret that choice later. Next I have to modify some rear quarter glass tracks to fit the front glass channels and then I'll be installing them in to the doors.
Me
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
05-17-18 05:44 PM - Post#2734212
Been super busy this spring. Got a chance to work on the car a few days ago. I decided to install a second rook brace for an additional dome light. I'm sure it may seem weird but I like lights damn it! I'll be wrapping up engine plumbing as well soon along with the exhaust. I had the PCM re-done and now she starts AND runs! Once those items are complete I'll be attempting the headliner. Of course I have to Dynamat also.
Me
Edited by TYTILIDIE on 05-17-18 05:45 PM. Reason for edit: No reason given.
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
05-19-18 03:11 PM - Post#2734365
Here it is wire tied and lights on.
Me
Belair-o
Reg: 03-26-07
05-20-18 05:57 AM - Post#2734406
Nice and bright! Good job on your build!
Regards, Doug
DonSSDD
DonSSDD
Reg: 08-21-01
05-21-18 04:05 AM - Post#2734479
    In response to Belair-o
Nice work, good progress.
Member #2194
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
05-30-18 04:50 AM - Post#2735345
Thanks guys!
Another update.
I got my fabulous check engine light working. I didn't realize that the other wire went to 12v.
I also figured out the tack strip for the headliner....I think
Only thing I don't get...what holds it down around the quarter glass? The moldings?
Also, anyone know what these go to?
Me
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
05-30-18 05:45 AM - Post#2735355
Those two pieces looks like what I have and mine had the windless attached to them and they are installed where I have in the picture and they also hold the kick panel in. You should be able to hold them in place and see where the mounting screws go. Hope this helps. Lamar
Attachment: IMG_4761_-_Copy.JPG (2.81 MB) 8 View(s)
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
05-30-18 06:41 AM - Post#2735364
    In response to PLS
Well that makes sense. I hope I wasn't supposed to install that first.
Thanks!
Me
PLS
PLS
Reg: 06-07-12
05-30-18 08:34 AM - Post#2735381
My car is a two door hardtop so I'm not sure that your will be like mine but as far as installing them I think that as long as you have them in before the trim that goes around the headliner and down to the pieces that trim out the dash will be good. Its hard to explain Lamar
Attachment: IMG_4767__3_.JPG (881.19 KB) 6 View(s)
This is the metal piece and my original windless, this goes on the passenger side.
Attachment: IMG_4768__2_.JPG (863.23 KB) 7 View(s)
This is how they go together
Attachment: IMG_4773__2_.JPG (852.76 KB) 7 View(s)
The metal piece, the windless and the kick panel
Attachment: IMG_4774__2_.JPG (892.5 KB) 7 View(s)
The windless is sawn to a piece of thin cardboard. This is my original which is pretty brittle and the one that the guy that installed my headliner made for me.
Attachment: IMG_4775.JPG (69.77 KB) 6 View(s)
The windless and cardboard are attached to the metal piece using these stakes.
Edited by PLS on 05-30-18 08:36 AM. Reason for edit: No reason given.
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
06-10-18 04:32 AM - Post#2736475
    In response to PLS
I took the car to have the exhaust built Friday. It turned out great! My main gripe is that my guy didn't think 2.5" was feasible so we went with 2.25" I had Magnaflow mufflers installed between the frame and the quarter panel, it's tight but it will work. I also had the tips extend out a little further than normal since I am going to install flamethrowers at some point (I think). The exhaust tubing looks kind of silly from the side but you can't really see it anyway when the car is on the ground unless you bend over.
When I picked the car up I didn't have time to drop it back off at my shop so I took it home. The next morning, I went for a very early morning walk and took these pics. This car is so sexy. I was actually really worried I picked too dark of a red but it really does look good I think.
Me
DonSSDD
DonSSDD
Reg: 08-21-01
06-10-18 04:48 AM - Post#2736477
Good idea on the mufflers. The car looks great.
Member #2194
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
06-16-18 05:54 AM - Post#2737143
Thanks Don. Here is how the car sounds now....
https://www.youtube.com/watch?v=ki1BAuRPep4
https://www.youtube.com/watch?v=ehGc8Q8eA7Q
All the plumbing is done. I have to replace the trans cooler because it leaks, YAY!! Other than that, coolant is in. Next I have to figure out this rear disc brake conversion. The bleeders face down and Pirate Jacks says I have undo the upper caliper bolt, tilt it back, put my caliper tool in there and bleed it that way. That seems overly ridiculous to me. I may go back to the drum brakes.
It also turns out I screwed up my steering shaft, I welded the Borgeson Joint at the Wrong angle. So I need to do that as well. Once those 3 things are done it will go to the alignment shop then I can start putting the interior together.
Me
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
06-18-18 09:13 AM - Post#2737362
dude, that sounds so sweet!!!!
Griff
2005 Yukon XL
2009 Silverado
2011 Escalade ESV
Techhead
Techhead
Loc: Etobicoke, Canada
Reg: 10-25-05
06-18-18 09:35 AM - Post#2737368
Excellent sound out the exhaust.
58 Delray in disaray
Execution time: 0.134 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:52 PM
