Username Post: tail lights won't turn off        (Topic#343233)
Denver56BelAir
Denver56BelAir
Loc: Parker, Colorado
Reg: 01-11-05
03-11-17 01:42 PM - Post#2680915
My tail lights won't turn off unless I disconnect the battery. When I pull the wire going from the light switch to the rear lights they shut off. When I connect the wire to the terminal on the light switch the tail lights turn on. Brake lights work fine. Headlights function as normal.
Is it a bad switch not turning off my lights? Is there some other wiring from another source I should check?
Paul
Parker, Colorado
56 BelAir Post, T56, 327, 4:11, Astro custom chrome steel wheels,
http://tinyurl.com/56belair
03-11-17 02:48 PM - Post#2680928
    In response to Denver56BelAir
Is the black wire on the correct terminal? Do the front park lights work normally? Do you have 4 way flashers? Is the 4 way switch activated?
Link to switch terinals.
Edited by acardon on 03-11-17 02:49 PM. Reason for edit: No reason given.
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
03-11-17 04:32 PM - Post#2680946
    In response to acardon
Please take a look at the picture of my wiring on my switch on the tinyurl in my signature. That might address your questions about the existing wiring.
The front park lights have never worked. 4 way flashers have never worked. Blinkers used to work, they don't now. What is or where is a 4 way switch?
Paul
Parker, Colorado
03-11-17 06:53 PM - Post#2680970
It looks like you have the gray dash light wire next to the tail light wire, instead of on the dimmer post. Try taking the gray wire off the switch and see if they go out. You may have the dash lights wired wrong.
Aftermarket tilt columns have 4 way flasher switches.
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
03-16-17 08:15 PM - Post#2681894
I'll try taking the gray wire off the post.
Paul
Parker, Colorado
warpwr
warpwr
Loc: Santa Clara, CA
Reg: 04-11-06
03-16-17 09:40 PM - Post#2681903
The gray wire goes on one of the the three terminal posts next to your thumb in your photo.
http://warpwr.dctechcorp.net/images/56%20light%20w ...
Vaughn
56 Delray 327, 5 spd
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
03-18-17 10:55 AM - Post#2682092
Taking the gray wire off didn't make the tail lights turn off
Paul
Parker, Colorado
DECEASED
03-19-17 01:01 AM - Post#2682164
The gray wire isn't the issue. The issue is that the black wire is connected to the wrong terminal on the switch. Before you do anything else, look at the drawing posted by acardon. Then remove the black wire from the terminal it is connected to now and re-connect it to the correct terminal as shown on the drawing.
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
03-19-17 11:36 AM - Post#2682223
Ray,
The parking lights turn on when I pull the switch one notch. The headlights turn on and the parking lights turn off when I pull the switch again.
The black wire looks to be in the same exact spot as the drawing. Keep in mind the drawing referenced shows the switch from the bottom and my pictures it from the top.
When I disconnect the black wire, the tail lights go off. I'm suspecting the switch isn't turning the rear tail lights off.
Thoughs?
Paul
Parker, Colorado
niftyfive
Loc: Durango, Colorado
Reg: 02-07-05
03-19-17 07:58 PM - Post#2682295
Hi Paul, unless there was another change made to the circuit prior to the lights staying on I'd say you have a bad switch. Replacing it may also cure your lack of front parking lights also.
Jim, Durango
NIFTYFIVE
03-20-17 06:16 AM - Post#2682368
    In response to niftyfive
It's designed for the front parking lights to go out when the headlights are on. The headlights and parking lights use the same circuit breaker in the switch. If both were on, it would cause a overload.
niftyfive
Reg: 02-07-05
03-20-17 06:53 AM - Post#2682377
Pauls prior posts indicated that front parks have never worked.
NIFTYFIVE
03-20-17 10:22 AM - Post#2682399
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
03-20-17 04:48 PM - Post#2682465
Parking lights do work. I mis-spoke early in the tread. Before I attempt getting a new switch, is there any other wiring I can check? Does the black wire from the light switch go ANYWHERE under the dash before it goes to the tail lights?
Could there be a loop somewhere? I'm pretty good with electronics, and I deduce the switch is bad...but...I'm not ready to buy into a bad switch.
Actually, I should, I've replaced that switch about 4 times in the last 12 years.
Last thoughts?
Paul
Parker, Colorado
03-20-17 06:12 PM - Post#2682476
If taking the wire off the switch kills the tail lights, the wire isn't picking up voltage from anyplace else. You could take the wire off the switch and measure the tail light terminal for voltage with the switch off. You could also temporiarly put the black wire on the front parking light teminal or the headlight terminal and see if they come on and off with the switch.
niftyfive
Reg: 02-07-05
03-20-17 08:32 PM - Post#2682505
Paul, looks like your narrowed down. Curious, what is the gauge by your left knee & it looks like a button switch maybe above it next to the column?
NIFTYFIVE
warpwr
warpwr
Reg: 04-11-06
03-20-17 09:14 PM - Post#2682510
Last thoughts?
My last thought would be DON'T buy a repro switch. They aren't very well made.
See if you can find an original on eBay or from someone on this site.
http://www.ebay.com/itm/1955-1956-chevrol et-headli...
Vaughn
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
03-21-17 03:31 PM - Post#2682642
Not sure what picture has my left knee.
Paul
Parker, Colorado
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
03-21-17 03:31 PM - Post#2682643
    In response to warpwr
All I've dealt with a reproductions. No more. I'll get the one off ebay.
Paul
Parker, Colorado
niftyfive
Reg: 02-07-05
03-21-17 05:09 PM - Post#2682664
Where your knee would be.
Can't figure how to attach picture. It's in your picture post, a shot under the dash.
NIFTYFIVE
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
03-23-17 03:36 PM - Post#2683002
I took the headlight feed off the switch, I put the rear tail light on the lead on the terminal of the front lights. the problem is the switch. I can control the tail lights with the switch while they are connected to the headlight terminal.
Paul
Parker, Colorado
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
03-28-17 05:55 PM - Post#2683922
I bought a replacement stock switch, it's an original unit, not a reproduction. I can't seem to pull the arm out to turn on the lights. It's jammed in there. If I try to depress the spring to pull out the rod, no luck either. Can I disassemble it?
Paul
Paul
Parker, Colorado
warpwr
warpwr
Reg: 04-11-06
03-28-17 09:46 PM - Post#2683952
You can take them apart.
As I remember there are little steel balls under spring tension that fly out in all directions if you are not careful. These are what make the switch click and hold when moved to the different positions.
I think what may have happened to your switch is that you are supposed to pull the headlight switch to the full on position before pressing the button to remove the knob and shaft.
If that wasn't done before and removal was forced then when the knob was put back in it became jammed when forced back in.
Take apart that POS reproduction first for practice maybe.
Good luck.
Repro top, OEM bottom
OEM left, Repro right
Vaughn
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
06-03-17 09:12 AM - Post#2694146
I replaced the switch. The tail lights still won't go off when I have the switch in the off position. How do I remove power to the switch all together? Is it the red or white wire?
If I disconnect yellow, the front lights go off. If I disconnect ANY OTHER COLOR (one at a time) all lights stay on with the switch in the on position. I have an EE degree and can't figure this out. censored it.
Paul
Parker, Colorado
06-03-17 10:34 AM - Post#2694158
The red wire feeds power to all the lights on the switch. Notice, there is a unused terminal next to the tail light terminal in this drawing. Is there a wire on it? If so, remove and test. Head light switch drawing.
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
06-03-17 01:05 PM - Post#2694181
When I remove the red wire going to the switch ( have the switch removed from dash) The front lights and tail lights both Orange and Yellow respectively STAY ON.
Paul
Parker, Colorado
DECEASED
06-03-17 03:35 PM - Post#2694202
Remove each wire from the switch one at a time and check that wire for voltage. Besides red, the only other wire that should have voltage is the white one, which comes from the dome light. The switch grounds that white wire when you want to turn the dome light on. If any other wire has voltage when disconnected, leave it off the switch for the time being and see what your tail lights are doing then.
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
06-03-17 05:42 PM - Post#2694226
There is a gray wire between the black and the red. When that gray wire is disconnected (along with the red and white dome light) the rear lights go off(with switch in off postion). Seems to me that gray wire is always giving power
Paul
Parker, Colorado
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
06-03-17 05:48 PM - Post#2694227
I fixed the problem. The gray wire was on the same bus as the tail lights. I moved it to the correct terminal. Now the tail lights go off when the switch is turned off.
Thanks guys.
Paul
Parker, Colorado
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
06-03-17 05:49 PM - Post#2694228
last thing. I need to get the wire from my light switch to my lighter. Can I buy a pre-made wire with connectors?
Paul
Parker, Colorado
Execution time: 0.112 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:24 PM
