Username Post: Truck bed repair        (Topic#343220)
doubleE
Loc: Eagan MN
Reg: 06-02-03
03-11-17 08:00 AM - Post#2680861
Trying to decide what to do with the steel bed on my 72 fleet side short bed. The truck spent most of it’s life in Arkansas. The rear bumper says “Clinton Arkansas”, Where ever it was they must have had a lot of fine red colored dust that infiltrated every nook and cranny. This included the underneath support structure of the bed. This in turn held moisture that caused rust from the bottom up. There are pin holes – up to 1/8th inch on the top surface of the bed. By looking at these holes it’s easy to see just where the cross support braces are.
So what to do? At this point in time I’m not ready to sink in $$ to replace the steel bed (or replace it with a wood bed). I use the truck mostly on weekends, local car shows, and misc hauling stuff like lumber, black dirt, etc. I would like to arrest the rusting to preserve the integrity and strength. One thought is to apply a DIY roll-on bed liner or install a rubber bed mat, or both. Each of those would run under $100. Anyone have experience with these rubber mats like the "DEE ZEE" mat?
About 10 years ago I seem to recall Eastwood had a paint product meant to fill pin holes in floor pans and the like but I don’t see it in their current catalog.
So looking to see what others have done or tried and how successful these were. I do use a tonneau cover now so it’s not so much an appearance issue.
Eric
Edited by doubleE on 03-11-17 08:06 AM. Reason for edit: No reason given.
JimKshortstep4x4
Chevytalk Moderator & "16th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
03-11-17 08:38 AM - Post#2680869
    In response to doubleE
A friend of mine used a rubber mat in his bed and it promoted rusting of the surface. I have had good luck with spray on bed liners.
Are the rust holes mainly over the cross supports such that you cannot get at them?
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
doubleE
Loc: Eagan MN
Reg: 06-02-03
03-11-17 09:40 AM - Post#2680885
The rubber mat - trapping condensation under it was one of my concerns. Would think using the tonneau cover would minimize this. And when I did haul dirt, afterward I would pull the mat, hose down the bed and mat and allow to completly dry before reinstalling the mat.
Yes the pin holes are only where the cross braces are underneath - thus my theory that dirt that accumulated in the braces over time trapped moisture that caused the rust. other than where the braces are, the bed is solid. I do plan to see if I can use my high pressure washer to remove any dirt still there. Would definitely want to do that before trying to apply a bed liner coating. Not sure what kind of access (underneath) there is to flush the dirt out.
Eric
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
03-11-17 07:21 PM - Post#2680976
The problem with rust is that you need to either cut it out or replace the rusty pieces or it will continue to keep eating the metal.
There are some paints that will kill the rust and seal it so it doesn't keep spreading.
71 Chevelle BBC powered
2010 GMC Sierra crew cab 4X4
JimKshortstep4x4
JimKshortstep4x4
03-12-17 04:11 PM - Post#2681120
If you can clean inside the supports as in pressure washing and get the interior dry, including blowing it out with compressed air then a product like POR will do a pretty good job of covering the rust. Applying the POR so that complete coverage is done can be time consuming! I have used a pump style garden sprayer to spray POR. Getting complete coverage internally could mean a very messy job!
You could end up drilling access holes in addition to any existing openings.
Execution time: 0.133 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:58 AM
