Username Post: 427 Block        (Topic#342816)
miket
Loc: Pheonix
Reg: 01-14-05
02-21-17 03:43 PM - Post#2677882
I am in the process of looking for a 67-69 427 block for my 69 Caprice. I have found an original short block casting 3916321 with original steel crank/rods and pop up pistons from 67. The stamp pad indicates this was a "CE" motor. Not sure if it was an L71/88/89. Whats it worth?
69 Caprice Custom Coupe 427/390hp
78 C10 Big Ten 350HO
Edited by miket on 02-21-17 03:44 PM. Reason for edit: No reason given.
ptjsk
ptjsk
Loc: Northern California
Reg: 05-30-08
02-22-17 08:13 PM - Post#2678114
    In response to miket
It sure sounds like a good find.
The "CE" code designates a replacement, or over the counter motor does it not?
Steel crank is good. What is the bore?
Would it need to have the short-block rebuilt, or does it look like you can run it as it is?
Do you know anything about the cam? Hydraulic, or solid?
The 427/435's were all 4 bolt main. Is this one a 4 bolt?
A lot depends on what it is, but I would think it's worth every bit of 3K.
Pat
wagonmaster
wagonmaster
Loc: Loganville, Ga.
Reg: 04-28-00
02-23-17 04:22 AM - Post#2678139
    In response to ptjsk
According to the Corvette Black Book the 3916321 can be a '67 or a '68 390-400-430- or 435 HP unit...However CE is not listed, may be a replacement block as previously stated.
Hey T @!
Joe
miket
Loc: Pheonix
Reg: 01-14-05
02-23-17 06:45 AM - Post#2678163
Hi Pat....responses below.
Correct...warranty replacement from what I have come to understand.
Standard bore...it has not been rebuilt.
Unsure...but if nothing else just a freshening up.
I don't yet.
Yes it is a 4 bolt and includes numbers matching date code correct 3919840 bare heads.
Pat
Edited by miket on 02-23-17 06:49 AM. Reason for edit: No reason given.
ptjsk
ptjsk
Reg: 05-30-08
02-23-17 06:09 PM - Post#2678270
Wow...It sure looks like you're onto something there!
In your original post, I read just the shortblock, but it includes heads as well?
The number on the heads are for the higher horsepower rating.
Good find!
Sorry, I really don't have a clue as to what the replacement blocks are worth.
miket
Loc: Pheonix
Reg: 01-14-05
02-24-17 08:03 PM - Post#2678443
Good find!
Heads included...but looks to be bare. Seems these are the larger rectangular port closed chamber model. Thinking this motor was probably an 11.1 CR.
TAT_2
"18th Year" Silver Supporting Member, and Official CT Grim Reaper
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
02-25-17 05:18 AM - Post#2678464
WITH THE REC HEADS & CR IS PROABLY A L71 REPLACEMENT & SHOULD HAVE A SOILD CAM IF ITS IN THERE.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
miket
Loc: Pheonix
Reg: 01-14-05
02-25-17 08:23 AM - Post#2678476
    In response to TAT_2
No cam but that's my conclusion as well.
Execution time: 0.12 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:06 PM
