Username Post: WANTED CHEVY 327 ENGINE        (Topic#342777)
darryldayton
Reg: 02-07-17
02-20-17 01:00 AM - Post#2677557
Must be a USABLE (no junk) 327 with a draft tube for engine oil breathing. Bare block is OK or will buy complete engine.
Call Darryl 928-239-0017 AZ.
darryl@sedonarental.com
1980 MALIBU 406 CU. IN.
Reg: 03-26-17
03-29-17 04:08 PM - Post#2684084
    In response to darryldayton
I have a 1967, 327 short block.
It still has the crank & pistons in it with a spun rod bearing from back when I was in High School in 1978. It was in my 1967 Chevy Impala and I do know it is .030 over when me & my Dad rebuilt it.
Not sure what it is worth today?
Reg: 03-26-17
03-29-17 04:19 PM - Post#2684089
    In response to 1980 MALIBU 406 CU. IN.
I just checked on e-bay and I see the bare 327 blocks sell for $900 or more?
Cadiman1949
Cadiman1949
Loc: Albuquerque, NM
Reg: 05-19-17
05-19-17 03:04 PM - Post#2691934
Hello Darryl, My name is Rick and I called your phone number and left a message today. I have 2 late 1962 casting dates 327 engine blocks. They are 3782870 or "870" which are correct for early to mid 1963 Corvette. One is used with a standard bore that has been magnafluxed and pressure tested. It has a standard crankshaft and rods (no pistons). Main caps are included and it has the windige tray bolt/studs as well. The other is a 3782870 "Fitted" short block. It is factory new with pistons and cam bearing installed. There are no heads, crankshaft or rods with this block. Both have not been decked and still have factory "Broach Marks" and neither engine has anything stamped on the pad. In addition I have a pair of 3782461 "461 X" heads from a 1961/62 Fuelie. The heads are complete and have been pressure tested and magnafluzed as well. They have never been rebuilt so you could do what ever you like with them.
Let me know if you're still looking.
Execution time: 0.085 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:42 PM
