Username Post: brakes        (Topic#342763)
Randyd
Loc: w washington
Reg: 03-23-10
02-19-17 03:03 PM - Post#2677483
65 Chevy II Nova power brakes from fact. PO put on front disc. brakes and dual master. I have a very hard pedal and it acts like drum brakes, very hard to stop. Went to CPP web site and pulled up trouble shooting for brakes. It passed all the test on power vacuum no leaks and holds vacuum, good vacuum from motor 20 inches. Installed new wheel cyl. on back, new calp. on front. I bleed brakes, good flow from all and no leaks. need HELP Randy
02-19-17 03:29 PM - Post#2677488
    In response to Randyd
Ok, so this was a complete conversion kit from Cpp? New booster, mc matched to the kit?
Randyd
Loc: w washington
Reg: 03-23-10
02-19-17 04:47 PM - Post#2677498
No, just the MC and proportional value, which sits just under the MC. The booster is from original power brake set-up from GM. The MC is 1 inch. Randy
02-19-17 06:15 PM - Post#2677515
Engine off, if you step down hwrd on the brake pedal, then start the engine, does the pedal drop some?
Randyd
Loc: w washington
Reg: 03-23-10
02-20-17 12:29 PM - Post#2677636
Yes, it drops about 1/4 inch. That part of the check from CPP, which it passed. Randy
02-20-17 05:47 PM - Post#2677690
Are you sure the mc is properly sized for disc/ drum and power? Same for the combo valve. Usually if all else is right, the mc bore size can be wrong, a!ong with the pedal ratio..my 51 disc/ drum conversion, 7"dual diaphragm booster using a disc/disc, 70's Vette mc and matching combo valve, with a 10# rear residual valve, stops great with normal pedal pressure. Btw, mc has 1and1/8 bore size.
Member #409
02-20-17 06:57 PM - Post#2677708
My 67SS had factory power drum brakes, 9" single diaphragm booster, and a 1" bore master cylinder.
When I changed to discs using factory parts, I retained the 1" bore master cylinder. Works great, lots of boost.
You might consider a 1" master cylinder if you have 1-1/8", but I doubt it would solve your whole problem.
Just as a cross check, go to mpbrakes site and look at their power brake troubleshooting guide. I'm sure very similar to the CPP troubleshooter, but maybe they say something or recommend something that's not said at CPP.
Randyd
Loc: w washington
Reg: 03-23-10
02-20-17 08:47 PM - Post#2677739
    In response to Rick_L
Checked with msbrakes troubleshooting, CPP is more complete. My system has a metering value with the porportion value. Every brake site says 1 inch should be right with disc/drum. Guess I'll keep looking. Thanks for the impute. Randy
Execution time: 0.112 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:27 PM
