Username Post: Under Dash Wiring Harness        (Topic#342685)
ptjsk
ptjsk
Loc: Northern California
Reg: 05-30-08
02-15-17 07:18 PM - Post#2676938
Ok Guy's,
I'm ready to start assembling everything under the dash.
I'm going to replace the wiring harness and most likely thinking of Lectric Limited as I had good luck when I wired my Corvette using their parts.
Does anybody recommend any other harness they have used for their '55 Nomad?
Has anybody used Lectric Limited, and how did it work out for you?
Most importantly, should I put in the wiring harness prior to windshield (rain-gear) wipers, clutch, brake brackets, steering column, aftermarket plenum for heat and air....etc?
Or should I put all of the previously mentioned items in prior to the wiring harness?
What are your suggestions on where to start?
Thanks in advance for your direction.
Pat
02-15-17 07:44 PM - Post#2676940
    In response to ptjsk
It looks like a pretty good harness. I have used American Auto Wire. They are a sponser and have a link under "Factory Fit" in the ads above.
Put everything in except the stuff that goes on the dash from the outside. The wires are flexible so they can go around the hard stuff.
Nomad Jack
Nomad Jack
Loc: Cape Cod, Ma.
Reg: 03-14-03
02-16-17 08:23 AM - Post#2676989
I also used the American Autowire "Factory Fit" harness and found it easy to work with. I liked that their harness is broken down into sections each with their own master connecter, so you only have to deal with the wires for the section you are working on.
Yes you want to install all the under dash stuff mentioned, some of the items will have wiring connections, the other stuff you need to run your wires around so as not to cause a fitment issue.
Nomad Jack
55 Nomad
http://www.jaxcars.net/55-chevy-nomad.html
57 3100 Pick-up
http://www.jaxcars.net/57-chevy-pick-up.html
31 LT Truck
http://www.jaxcars.net/31-chevy-truck.html
53 CJ3B Jeep
https://www.jaxcars.net/1953-cj3b-willys-jeep .html
WagonCrazy
WagonCrazy
Reg: 06-07-05
02-16-17 08:42 AM - Post#2676991
    In response to Nomad Jack
Another vote for American Autowire harness...I put one in my 57 9 passenger wagon a few years ago, and have never had an issue. Very complete kit...very good instructions came with it...very good customer support online as well. They have a section here in CT you can post your questions to and Donny is very quick to reply.
troberts
troberts
Loc: Southeastern NC
Reg: 02-05-14
02-17-17 08:06 AM - Post#2677112
    In response to WagonCrazy
Ditto on American Autowire...I restored my Nomad from ground up and put all new wiring front front to rear using the AAW complete kit. I have never wired a car prior to this, the kit is as previously mentioned set up in sections with excellent instructions and great tech support when I had a few questions. Had no problems at all!
T Roberts
ptjsk
ptjsk
Reg: 05-30-08
02-17-17 11:31 PM - Post#2677216
    In response to troberts
Thanks a lot for the responses Guys.
I did have AAW in it prior to the paint functioning and having to tear it apart again.
I know several wires were cut while removing the entire harness again.
But I got it out, and laid it on the floor. It looks as if I could order just a few of the plug in harnesses and I may be back in business.
I didn't complete the previous wiring, but I'm definitely giving it a go this time around.
Thanks again,
Pat
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
02-20-17 03:07 PM - Post#2677659
Give AAW a call. You may be able to send your current harness to them for repairs.
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
ptjsk
ptjsk
Reg: 05-30-08
02-21-17 08:22 AM - Post#2677803
    In response to BigDogSS
I think I will try that today.
Thanks for the suggestion,
Pat
5557mad
Reg: 11-17-11
02-23-17 07:19 PM - Post#2678273
no suggestion on wire but i always put the heater control in before the speedo cluster. makes it a lot easier
ptjsk
ptjsk
Reg: 05-30-08
02-23-17 10:48 PM - Post#2678309
    In response to 5557mad
Thanks for the tip!!
Execution time: 0.127 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:22 PM
