Username Post: 56 corvette powerglide        (Topic#342662)
GasWorksGarage
Reg: 01-30-17
02-15-17 08:06 AM - Post#2676845
Does anyone have a diagram of a 56 corvette power glide?
02-15-17 02:53 PM - Post#2676907
    In response to GasWorksGarage
Do you mean an internal parts breakdown, such as what would be in the oe shop manual?
GasWorksGarage
Reg: 01-30-17
02-16-17 08:02 AM - Post#2676988
I have a leak on the side plate where the detent linkage goes and I don't want to pull it off until I know what is back there.
02-16-17 11:02 AM - Post#2677017
Go to joeandhenrytransmissions.com, good diagrams.
GasWorksGarage
Reg: 01-30-17
02-16-17 12:11 PM - Post#2677026
thanks. they lead me to Northwestern Transmissions
I found the parts I need. Anyone ever pull the throttle valve cover off? Where the kick down lever is? What am I getting into?
56sedandelivery
Gold Supporting Member
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
02-17-17 08:27 PM - Post#2677205
Nothing really super complicated, but the bolts holding the side plates and tin to the cast iron Powerglide are very small, and strip easily. Just be careful, and don't get carried away tightening things up. 1/4" bolts with a 7/16 head, that are fairly short, strip easily. Your leaks could partly be the result of stripped bolts/holes.
I am Butch/56sedandelivery.
Execution time: 0.154 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:26 PM
