Username Post: connecting rods        (Topic#341608)
augercreek
Reg: 01-01-17
01-01-17 03:22 PM - Post#2668882
I have a 1962 chevyII 153 4cyl engine that I tore down some years ago. Now I'm putting new pistons on the rods but have forgotten to mark them when I disassembled them. Which way do they go?
Born 9/11/1940,live in Duluth Mn.Hobbies,IH tractors,gunsmithing,gard ening,faith in Jesus Christ.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-01-17 06:18 PM - Post#2668899
    In response to augercreek
the beveled edge faces the crank counter weight, the non-beveled edge faces the matched connecting rod
Edited by grumpyvette on 01-01-17 06:50 PM. Reason for edit: No reason given.
augercreek
Reg: 01-01-17
01-02-17 04:52 AM - Post#2668944
    In response to grumpyvette
This is a four cylinder engine so no bevel on rods.
Execution time: 0.106 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:27 PM
