 Page 2 of 2 <12
Username Post: 67 Rat Ramp!        (Topic#341410)
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
02-19-17 08:01 PM - Post#2677529
    In response to Andy4639
I got the wood steering wheel all filled in with the plumber putty. Now the fun part sanding it down! This along with the tilt will make the drive even better.
Attachment: wood_grain_steering_wheel4.jpg (101.83 KB) 27 View(s)
Simulated wood grain 2 spoke Impala wheel.
Attachment: wood_grain_steering_wheel6.jpg (54.97 KB) 27 View(s)
1 crack
Attachment: wood_grain_steering_wheel7.jpg (49.19 KB) 31 View(s)
2 crack.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
02-19-17 09:18 PM - Post#2677540
I spent months sanding on my truck. I don't ever want to see a long block ever again. The tilt column is the greatest thing. A new steering wheel has been on my list for a long time.
71 Chevelle BBC powered
2010 GMC Sierra crew cab 4X4
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
02-20-17 06:57 AM - Post#2677570
    In response to LUVmachine
The factory repro wheels are nice looking but they are not very strong. I like the 2 prong Impala wheel. I hope I can get it looking like new again.
Corvette wheels work on these trucks to with the right hub assembly that can be bought.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
02-20-17 09:09 AM - Post#2677588
What's involved with the hub swap to car pattern?
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
02-20-17 02:00 PM - Post#2677650
It's a direct swap. They hub is the same on either.I have seen even the horn buttons modified to fit them.
Here is a link to a forum talking about the hubs. I posted in this link.
http://67-72chevytrucks.com/vboard/showthread.php?...
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
02-23-17 06:04 PM - Post#2678255
I got the rear view mirror wired up tonight. Looks good to me!
Ran the wires under the gasket from the mirror down to the dash weep hole to the fuse block.
Attachment: T_C_mirror2.jpg (72.19 KB) 41 View(s)
Attachment: T_C_mirror.jpg (28.32 KB) 32 View(s)
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
02-28-17 10:51 AM - Post#2678952
Final mounting of the winch today. Got the 3/8" bar drilled and mounted under the bed and winch all tightened down. Ran the cables for it under the truck to the compartment to keep the battery out of the weather. Will run a wire from alternator to battery with a cut/off switch to charge it with and also a volt gauge to keep a eye on it when charging are needing charging.
Attachment: winch.jpg (44.71 KB) 35 View(s)
Winch mounted
Attachment: winch3.jpg (63.37 KB) 36 View(s)
Winch reinforecment under the bed
Attachment: winch2.jpg (69.74 KB) 28 View(s)
Battery mounting under the bed.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-02-17 05:31 AM - Post#2679282
Started sanding the SS Impala wheel for the Ramp Truck install. Once I get the tilt cleaned up and painted I'll install it.
These wheels are $400.00-$500.00 on E bay.
I'll have less than $200.00 in this one when done.
Attachment: wood_steering_wheel_sanding.jpg (76.19 KB) 33 View(s)
Started sanding on the simulated wood grain wheel last night
Attachment: wood_steering_wheel_sanding2.jpg (38.73 KB) 35 View(s)
I'll finish up with sanding tonight I hope and drop it off tomorrow for the finishing touches.
Attachment: wood_steering_wheel_sanding5.jpg (31.1 KB) 39 View(s)
Still some fine sanding but I think the thing turned out pretty good.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Edited by Andy4639 on 03-02-17 05:32 AM. Reason for edit: No reason given.
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
03-02-17 07:48 AM - Post#2679302
Looking good. You don't seem to ever fall short on the project list. I wish I had your motivation. I ordered a steering wheel for my truck last night.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-02-17 09:02 AM - Post#2679314
Sometimes I feel it's all I do but I can't help myself. I love it.
Between my 71 C-10, 64 SS Impala, dad's 56 Bel Air and this I stay pretty busy!
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
03-02-17 01:20 PM - Post#2679360
It's labor of love. Sometimes I feel like it's all I do too and sometimes I have a nice day and have plans to get a lot done and I can't get motivated to do anything.
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
03-02-17 06:05 PM - Post#2679430
I think I found a couple of projects if my parts get here tomorrow. I ordered a Hurst pro matic shifter along with the steering wheel. Once I get the shifter in and no longer have to deal with the old column shifter linkage I am going to attempt the steering column shortening trick. I want to sink the column in as far as possible. It's either that or stretch the cab and think the column would be much easier.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-24-17 10:54 AM - Post#2683086
Working on the ramp Rat a little today.
Got new seals installed in the windows and making new door panel patterns for new ones. Should look a lot better once done.
Attachment: old_door_panels2.jpg (130.1 KB) 30 View(s)
Attachment: old_door_panels3.jpg (64.14 KB) 44 View(s)
Attachment: old_door_panels4.jpg (131.36 KB) 28 View(s)
Door panel pattern!
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-26-17 04:19 PM - Post#2683474
Did a little work today on the Ramp. Cleaned up the door trim.Now to get the panels finished up and I'll have the interior just about done.
Attachment: door_trim_rusty3.jpg (94.22 KB) 33 View(s)
Rusty trim
Attachment: door_trim_rusty2.jpg (95.67 KB) 28 View(s)
00 Steel wool
Attachment: door_trim_rusty4.jpg (129.67 KB) 36 View(s)
A little elbow grease and 00 steel wool!
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
04-09-17 01:09 PM - Post#2685737
New hood letters, door locks, ignition key and glove box all installed with one key working them all.
Hope to get started back on the door panels this week also.
Attachment: New_hood_letters.jpg (119.92 KB) 25 View(s)
New letters for the hood.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
04-09-17 05:19 PM - Post#2685765
Door panel board done. Now to get them covered.
Glove box lock installed.
Attachment: drivers_side_panel.jpg (69.85 KB) 26 View(s)
Drivers side
Attachment: passenger_side_door_panel.jpg (58 KB) 33 View(s)
Passenger side
Attachment: Glove_box_key.jpg (39.99 KB) 29 View(s)
Glove box lock
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
04-02-18 01:16 PM - Post#2729720
Haven't updated this thread in awhile. Ramp has new push bumper installed with LED lights. Winch is operational with 2-6 volt deep cycle batteries tied to the truck battery with a 400amp contactor to cut it ON/Off from the dash.
Have all new 6 tires installed. Installed new to me exhaust manifolds. Did a fresh tune up during the manifold removal & install. Had to cut the old resistor wiring out of the harness and ran new wire for HEI. Have the air tank mocked up in the garage to start on that this coming weekend. You never know when you will need air on the side of the road.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-19-19 10:02 AM - Post#2757725
Been awhile since I updated this. The ramp has been going through some much needed adjustments and upgrades.
New tires all around that my son got me while he was working for a tire company. Less than $200.00 for all 6 tires. I also pick up the rear wheel S/S simulators for $50.00 and 2 68 front chrome wheels for a set of old Pony car wheels I had. I have all the marker lights working and installed a 5 gallon air tank and 2-6 volt deep cycle batteries in series to run the air compressor and charge them off the alternator.
I took the lights off the front push bumper and put LED lights there and used the old ones on the back for night time loading. I got a old Unity spot light and mounted it also.
I'm finishing up the tilt wheel column install today I hope.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Edited by Andy4639 on 01-19-19 10:07 AM. Reason for edit: No reason given.
 Page 2 of 2 <12
Execution time: 0.177 seconds.   Total Queries: 24   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:42 AM
