Username Post: Home Wiring Questions        (Topic#340986)
Charlie57
Charlie57
Loc: Lebanon, Tennessee
Reg: 03-30-08
11-30-16 09:21 PM - Post#2664019
I am adding a room in my attic, it will be about 280 sq ft. I have one spot left in the breaker panel, I would like to put in three ceiling lights and enough outlets that would meet or exceed any codes. What is the rules on outlet spacing. Can I run just one wire of 12-2 to cover all this?
Charlie
"Charlie's 57 Chevy" I made it's very own FaceBook page please visit and "Like"
http://www.facebook.com/pages/Charlies-1957-C hevy/214078481937849
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
12-01-16 12:29 AM - Post#2664030
    In response to Charlie57
Yes, you can, Charlie.
In my line of work I see hundreds of service panels every week from coast to coast. Send me a picture or your breaker panel with and without the deadfront cover in place. You may have some options you're not aware of.
Greg
'00 Explorer XLT 4.0 V6 Auto
12-01-16 07:44 AM - Post#2664053
Use LED bulbs for the lighting, a 20 amp breaker in the box and put the wall plugs on a 15 amp GFI outlet. I would use all 12 gauge/with ground wire.
65_Impala
Reg: 12-29-02
12-01-16 08:47 AM - Post#2664061
A 15A circuit and 14/2 wire would work fine. I always go 6' from a doorway then 12' apart putting receptacles around a room.
12-01-16 10:52 AM - Post#2664074
    In response to 65_Impala
I use 12 gauge on all wall outlets, because some girls are going to plug 2 1500 watt hair dryers and a curling iron into the same string, before the braker trips.
Or it could be because I have a 2 hp cut off saw, 2 hp table saw, and a jointer on the same circuit.
DECEASED
12-01-16 12:28 PM - Post#2664090
A 20 amp circuit wired with 12-2 w/ground will be adequate for the outlets and should conform to code.
However, if you are unable to install two breakers, connect the lights to one of the existing lighting circuits if at all possible. This way you will still have lights in the room if you should happen to trip the breaker for the outlet circuit.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
12-01-16 11:34 PM - Post#2664169
Square D Homeline single pole breakers are listed for use with two branch circuits. If you have a Homeline panel, You have more available options ban you think.
Greg
raceman6135
raceman6135
Loc: Calgary, Alberta, Canada
Reg: 11-04-02
12-02-16 11:50 AM - Post#2664218
Code is that there must be one receptacle within 6 feet (1.8 meters) from any given point along a wall. This does not apply if the wall is 24 inches (0.61 meters) or less wide.
Also, a receptacle is required within 6 feet (1.8 meters) of the door opening.
And don't forget that the circuit must be arc fault protected:
  • NEC Said:
210.12(B) Dwelling unit family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sun rooms, recreation rooms, closets, hallways - wiring methods require AFCI.
Charlie57
Charlie57
Reg: 03-30-08
12-03-16 06:23 PM - Post#2664445
    In response to raceman6135
Thanks for the replies, they are helping! I am posting pictures of the panel. I guess you call this a sub-panel, the main panel is outside.
It makes a lot of sense to run the lights on a separate circuit.
I will post some photos later but would like to try to tie into an existing circuit that has two switches and one light, would like to make it three switches and two lights.
Also should I drill holes through the studs and run the wire or just staple the wire to the studs like the rest of the attic.
[image]IMG_7198 by Charlie Shew, on Flickr[/image]
[image]IMG_7203 by Charlie Shew, on Flickr[/image]
[image]IMG_7202 by Charlie Shew, on Flickr[/image]
[image]IMG_7201 by Charlie Shew, on Flickr[/image]
[image]IMG_7200 by Charlie Shew, on Flickr[/image]
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
12-04-16 01:08 AM - Post#2664485
First, there's a group of three breakers, right side, near the bottom. Those are the arc fault breakers mentioned above. You'll need another one like them for the new bedroom.
Invariably you will likely have to pass between stud cavities. When you do, center the holes on the studs to prevent accidentally impaling the cable with a drywall screw. Most drywall screws are 1.25", but even if you use 1.5", you'll still be safe.
The "2 switches one light" setup sounds like a "three way" lighting circuit. Are you just intending to add this room to the same feeder? If so, be careful which cable you connect to.
There's a two wire one and a three wire one. Be sure to only feed from the two wire one. The three wire one is the common tie between the two switches that run the one light.
Greg
Charlie57
Charlie57
Reg: 03-30-08
12-18-16 04:39 AM - Post#2666571
    In response to CowboyTrukr
Update.
I'm still plugging away with my project. I've made some progress and have some insulation up, most the wiring done. So here is my next questions.
Originally, you walked up about six steps to the bonus room now when you walk up those steps you turn and walk up 6 more steps into the new attic room. Currently there is two light switches, at the top and bottom of the original steps that control the same light for the steps. I want to add a light and a switch to the same circuit so that when you turn any light switch the light goes on or off. Can I do this and how?
Here is the original steps, the light switch is on the right and the light is on the wall.
[image]Untitled by Charlie Shew, on Flickr[/image]
Here is the light switch at the top, it controls the light at the steps, a ceiling light and the ceiling fan.
I want to add a third system and a second light on this wall. Any sugguestions?
And finally, I need to wire up my three new lights. I have wire individual switches for each light with one power source coming into the box. Now I need to find a source of power for the lights.
DECEASED
12-19-16 06:40 PM - Post#2666853
If you want three or more switches to control any light or group of lights, use "4-way" switches. These have 4 terminals and are wired like this:
http://www.how-to-wire-it.com/wiring-a-4-way-switc...
Charlie57
Charlie57
Reg: 03-30-08
01-01-17 04:46 PM - Post#2668888
Hey Guys,
Thanks for all the tips, advice and information. I just got the 3 way switch installed and working. It was a little intimidating trying to find the correct wires but with your help I got it done.
Thanks,
Charlie
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
01-09-17 10:50 PM - Post#2670395
Go talk to the "Code" people and verify what your code says.
Here, I think that it was an outlet no more than every 4', and the number on a circuit was limited.
Custom_Deluxe_20
Custom_Deluxe_20
Loc: Stevens PA USA
Reg: 04-05-02
07-23-17 04:38 PM - Post#2701097
Arc fault thankfully are not required in our area as they are pia
92 SWB 4X 305 5peed Powetrax out back Posi-lock ft 72 LWB fleet, 454,400 t,12 bolt w/3.73 and locker #3 Roll on forever
Execution time: 0.083 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:28 PM
