Username Post: Overheating        (Topic#340552)
Jasonda
Reg: 07-07-13
11-12-16 06:10 PM - Post#2661228
Please forgive me I had trouble getting this to add. Also this has probably been discussed before. I have a 350 that was rebuilt and dyno tested at 425 hp. RebuilDer paperwork lost do to a death. Engine runs 230-240. New wp, 160 tstat with bypass holes. Upper hose Builds pressure and pops off. Head gaskets and heads look fine.
I see a water port in the middle of the head with no port in the block in the same place. Please help.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
11-13-16 05:05 AM - Post#2661300
    In response to Jasonda
My first thought is the water pump, V-belt and serpentine are reverse rotation from each other.
Jasonda
Reg: 07-07-13
11-13-16 07:59 AM - Post#2661312
    In response to junkman104
Already checked that. It is a v-belt. It does have a chrome pulley, would that be a concern?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
11-14-16 06:03 PM - Post#2661601
But is it the right water pump?
GMMark
Reg: 11-23-18
11-24-18 02:11 PM - Post#2752268
Post pics of the heads and engine
Texasray
Texasray
Reg: 11-01-16
11-15-19 07:48 PM - Post#2780253
    In response to GMMark
Do you ever feel flow thru the lower hose? Does the bottom of the radiator near the outlet to the pump get hot? If no to those questions then you have no flow. Probably first check (as Noted earlier) do you have a serpentine reverse rotation W/P on the engine. You said you were using v belts so...
As for the hole in the head, is there one in the head gasket. And yes, pictures would help.
Sam
Execution time: 0.087 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:36 AM
