Username Post: disc. brakes        (Topic#340548)
Randyd
Loc: w washington
Reg: 03-23-10
11-12-16 05:15 PM - Post#2661218
Some where along the line, someone PO, put disc. brakes on the front of my 65 nova. Trying to find out which ones I have, to replace the calipers. All I can find on the cal. is the letters GM N. No other numbers or letters match. So do I have stand. or metric and how to tell them apart? Randy
Member #409
11-12-16 05:24 PM - Post#2661222
    In response to Randyd
The "Chevelle" calipers have about 7" between the mounting bolts. Replacements should be from a 69-72 Chevelle.
The "Malibu" (metric) calipers have about 5.5" between the mounting bolts. Replacements should be from a 79-82 Malibu.
Since you can put Chevelle style brakes on a Nova with almost all factory bolt on parts, they are probably the most likely if you have stock suspension.
Randyd
Loc: w washington
Reg: 03-23-10
11-13-16 10:13 AM - Post#2661333
    In response to Rick_L
Thanks Rick_l I will check on it tomorrow, football today. Randy
DECEASED
11-13-16 12:35 PM - Post#2661350
Look at the pads. They will usually have a number on them like "Dxxx". That can be back-referenced to find out what kind of caliper they belong to.
Randyd
Loc: w washington
Reg: 03-23-10
11-14-16 12:55 PM - Post#2661548
Measured today looks like I have metric. Thanks Randy
Execution time: 0.103 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:47 PM
