Username Post: Cooling issues        (Topic#340465)
sharpsshot
Reg: 11-08-16
11-08-16 10:58 AM - Post#2660586
I have a unusual set-up I bought and need help with cooling issues. I'm posting in camaro forums because front clip and suspension is from a 1978 camaro, not so much the engine. It is a 400 SBC from casting number it is 70-73 possible 4-bolt. It has a serpentine drive,heads,TBI and dist. and ECM that according to ECM code came from a 89 350 "K" LO5. Seller told me heads had steam holes installed. The engine has always ran around 210 when warmed up, which didn't really bother me. I recently due to leak in cab removed heater hoses and plugged holes in motor. Now, what it does is at idle temp stays around 190, running in high gear temp. goes up to 230, if I accelerate so that transmission down shifts temp goes down to 210-215. I'm baffled, please help.
DECEASED
11-09-16 09:46 AM - Post#2660707
    In response to sharpsshot
Instead of plugging the heater connections, try running a single hose between the two connection points. Please post again with your results, whether you see any improvement or not.
sharpsshot
Reg: 11-08-16
11-23-16 03:30 PM - Post#2662877
Hi Ray, worked like a champ, connected the two heater hose ports and operating temp. has dropped to 190. Thanks for your advice.
DECEASED
11-24-16 08:38 AM - Post#2662953
I'm glad to hear the hose worked out well for you. Thank you for your feedback.
Gmctrucks
Reg: 03-15-17
01-29-18 04:02 PM - Post#2722621
That was super great help I learned something today.
Execution time: 0.162 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:21 PM
