Username Post: Need Help with Eyebrow Rings.        (Topic#339857)
ptjsk
ptjsk
Loc: Northern California
Reg: 05-30-08
10-15-16 06:40 PM - Post#2656741
Ok Guy's,
I have a great set of eyebrow rings, except that the studs are broke off.
And of course they have already been chromed.
Short of drilling a hole through the ring, what resolve have you guy's completed?
Thanks in advance, Pat
Attachment: Eyebrow_Rings_2_.jpg (205.84 KB) 73 View(s)
WagonCrazy
WagonCrazy
Reg: 06-07-05
10-16-16 06:17 AM - Post#2656787
    In response to ptjsk
JB Weld a deep nut on it, then put a short bolt thru...
If you let the JBWeld compeltely cure before you put any torque on it...it might hold.
55MAS
Loc: North Coast, Ohio
Reg: 12-19-01
10-16-16 07:49 AM - Post#2656800
    In response to WagonCrazy
Won't that require a huge hole in the fender for the nut to clear?
WagonCrazy
WagonCrazy
Reg: 06-07-05
10-17-16 12:21 PM - Post#2656995
    In response to 55MAS
Uhhh....probably.
another idea may be to JB weld a short stud to the backside of the trim. You might need to carefully grind away some material at the back of the trim piece, to allow space for enough JB weld to hold the stud firmly once dried. But not so much that it creates a glob that interferes with it sitting smoothly against the fender sheet metal when you mount it.
Otherwise, you're looking at new eyebrow trim pieces $$$$
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
10-18-16 04:00 AM - Post#2657134
If they are made of stainless steel...
I had a similiar problem with a piece of SS on my 4dht that served as a junction point for 3 other SS trim pieces just behind the rear door. The pins were also broken off.
I took it to a friend who welded on a couple of escutchin pins (steel, thin, long, threaded bolts with the heads cut off. It looked ugly but I was able to buff out all of the discoloration, no problem.
Stan
It's all good. mostly
55MAS
Reg: 12-19-01
10-18-16 09:17 AM - Post#2657172
    In response to 4dr 57
Stan
They are chrome plated a zinc diecast aka potmetal.
5557mad
Reg: 11-17-11
10-21-16 03:24 PM - Post#2657671
i put the eyebrows on my nomad with clear silicone. had same as you nice eyebrow but no studs. used a tube of clear silicone caulk. if i need to ever remove then i can scrape the caulk out and they will come off. been on my car for 10 years and still nice and tight. also no drilling
ptjsk
ptjsk
Reg: 05-30-08
10-22-16 07:19 AM - Post#2657746
    In response to 5557mad
Thanks for the information.
That may just be the way to go.
Thanks again,
Pat
calantpe
Reg: 03-23-17
03-25-17 07:32 AM - Post#2683195
You might want to try 3M moulding tape. It is a double sided tape that has very strong adhesion. It comes in different widths. This might work well with no holes or mess to worry about.
Calantpe
Edited by calantpe on 03-25-17 07:32 AM. Reason for edit: No reason given.
Execution time: 0.066 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:13 AM
